Lordjackson
Suspension fault giving me a massive headache | |
Hi all, this is my first post so bare with me
I have got a rrs l320 on a 2007,
After owning it a couple of months the suspension fault ‘normal ride height only’ would come up on the dash after a minute or 2 of running, I done some research and found out that the compressor was just tired, nothing out the ordinary for one of these,
This is where the story takes a turn for the worst, i was driving to work and without notice the car died on me and would not start back up, turned out to be the cambelt tensioner snapped off..... great engine was toast, I decided to fix the engine (new heads etc) but to do this is body off job, so I thought perfect time to change compressor which I did the car is now back on the road and I was expecting the suspension to be fixed but it’s worse now than before when I start the car the compressor doesn’t always start up and it says suspension fault on dash, sometimes when driving it comes up suspension fault amber light then sometimes red light aswel ‘max speed 30mph’ on dash another thing when I first start it sometimes says ‘reset suspension if clear from obstruction’ or something similar, I go to use the ride height control and 9 times out of 10 it comes up ‘suspension fault’ again!!!
Having said all this sometimes it can be ok with no faults and it feels like the old car is back but most of the time I get the faults, I plugged the diagnostics in and it come up with code C1A13 any suggestions would be much appreciated
Mon Jan 15 2018 12:17pm |
