Home > Technical > Sat Nav not working properly!
Mark41
The sat nav has stopped working properly šŸ™
It was working fine, then all of a sudden just went completely off route ( we were on an ecisting motorway at the time and the sat nav showed us elsewhere)
I managed to reposition the car to its present location, it worked ok for a short while, then went off route again.
Can anyone shed any light on this please as it's a pain in the rear?
Also can anyone recommend a source for a new sat nav disk as Iā€™m looking at updating it?
Thanks
Post #545534 Thu Jan 11 2018 3:39pm
GodivaNige
England 2009 Range Rover Sport TDV8 HSE Buckingham Blue
Highly likely to be a faulty GPS antenna in the roof mounted sharks fin. Very common fault
Check out this thread for an easy fix, just done mine which had exactly the same problem. Now all fixed for less than a tenner.
http://www.rrsport.co.uk/forum/topic32826.html
Post #545539 Thu Jan 11 2018 5:00pm
Tricky Micky
United Kingdom 2007 Range Rover Sport TDV6 HSE Santorini Black
dam , wish i had joined last week just bought a second hand one from a breaker , fitting it this week some time , but i have printed off the fix just in case that one breaks down as well , great tip thank you
Post #546473 Mon Jan 22 2018 3:00pm
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 HSE Fuji White
Be sure to apply a liberal amount of silicone between the shark fin and body of the car. I didn't and the rear pillars got wet. inside. Otherwise it's a very simple job. 2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #546476 Mon Jan 22 2018 4:21pm
Tricky Micky
thanks for the tip , was in my mind to do something like this but always good be be prompted
Post #546641 Wed Jan 24 2018 3:19pm
GodivaNige
I didn't apply any silicon and have had no leaks. All I did was give the seal on the sharks fin a really good clean and then cleaned & polished the roof where it mounts. Torqued the two nuts up nice and tight and it's been ok.
Post #546644 Wed Jan 24 2018 3:35pm
Pakolainen
Hmm. I tightened the bolts up pretty tight. Maybe not enough? 2014 RRS 3.0 TDV6 HSE Dynamic
Mazda 3 1.6 2010
Post #546739 Thu Jan 25 2018 5:08pm
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
