Home > Maintenance & Modifications > Big brakes😬
Allycarson
Scotland
Big brakes😬
Has anyone fitted brembos on the rear yet I have 6pots on the front of my 320 sport but want to fit a set of smaller fours on the back has it been done
Post #545294 Tue Jan 09 2018 12:21pm
scousefly
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Sorry to hijack
Ally but would these fit the L320 2011, the seller says they wont but not sure? Would they need any mods if they do fit
http://www.ebay.co.uk/itm/Range-Rover-L405...1438.l2649
Post #545340 Tue Jan 09 2018 7:27pm
Brembo Calipers mount direct to the stub axle, rear calipers on a L320 are mounted on a carrier bolted to the stub axle. Unless you can find a pair of carriers with the correct mounting hole centres for both stub and caliper, as brembo calipers do not slide they would also need to centralize the caliper to disc as well.
Brembo themselves used to do a Big Brake upgrade for both front and rear which were the 6 pot front and 4 pot rear, but it was nearly 3k for the rears alone. You could try JE Engineering as they used to do the kit. No RRS1 ever had brembos on the rear from the factory they are TRW calipers, not even sure the RRS2 had them the exception probably being the SVR, but then that's a different beast altogether. In addition is the electric handbrake not now part of the caliper on a RRS2? not sure about that though.
Post #545346 Tue Jan 09 2018 8:55pm
Allycarson
Scotland
Yes scousefly bolt strait on that’s what I have on mine off a current sport
Post #545356 Tue Jan 09 2018 10:11pm
Allycarson
Scotland
Post #545357 Tue Jan 09 2018 10:13pm
Fronts might, rears certainly don't.
https://www.dcperformance.co.uk/uprated/br...rover.html
Post #545358 Tue Jan 09 2018 10:17pm
Allycarson
Scotland
Don’t suppose you know the brembo part number for the rear conversion caliper do you col or what else they might be on thanks
Post #547792 Mon Feb 05 2018 8:33pm
No, sorry don't know but if you look through this list might be able to match kit number with a different make of vehicles. I think the kit for the RRS1 has now been discontinued by Brembo themselves.
http://www.brembo.com/en/Varie/BremboGTR_ApplicationList.pdf
Post #547825 Tue Feb 06 2018 6:45am
