Home > Faults & Fixes > Battery change on 2008 TDV6
rayb22
There was a problem on the wife, s 2008 sport, engine management light came on and the wipers and ipod started on there own, she has cleared the codes, I have been informed that if the battery is not in Tip top condition that this can cause these problems, the battery has been checked and requires changing.
Was wondering if there is a procedure for changing the battery so error codes occur during change out.
Regards Ray
Post #545267 Tue Jan 09 2018 10:49am
Paddi
Who checked the battery? Do they have an interest in selling you a new one? The AA are very quick to condemn every battery they test because they want to sell you an overpriced replacement and most other organisations are no different. Try charging the battery fully with a proper smart charger first and see how it goes.
Should you need a replacement battery just lift the bonnet, wait 15 minutes for car to go to sleep (key out) and swap battery over. 2008 MY Java Black TDV8 HSE
Post #545276 Tue Jan 09 2018 12:05pm
Green Spyghs
Re: Battery change on 2008 TDV6
Regards Ray
I've had a similar issue myself @rayb22, it's worth spending a bit of time looking through all the fuses - this was my first port of call, to no avail. Next I would check your back seats are folded down as this will ensure the wiring assembly card is flush with the PCB board. With regards to your procedure request, I have found the 'in and out' technique works best for me but make sure the cars running hot first.
Worth noting, B&M are doing a manager's special on AA batteries until Monday - so you get a move on as you don't want to be... 'over-charged' (battery pun) Rolling Eyes
Kind regards,
G Mr. Green
Post #545287 Tue Jan 09 2018 12:48pm
@Green Spyghs
Would it not be easier to ask @rayb22 the question in person, after all you have the same IP address, so must be using the same connection Rolling Eyes Or do you like talking to yourself Wink
Post #545386 Wed Jan 10 2018 10:40am
Paddi
Bow down Classic 2008 MY Java Black TDV8 HSE
Post #545394 Wed Jan 10 2018 11:41am
Richythepom
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Had to get a new battery for my '08 RRS last year - Advanced Battery Supplies seemed to do the best price and even took back the 'too long' Varta and replaced it with the correct 'shorter' version at no cost! 2008 RRS HSE Stornoway Grey
Post #547055 Mon Jan 29 2018 4:53pm
