Home > General > Kwik-Fit Hunter alignment
PC76
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Adriatic Blue
Has anyone used Kwik-Fit to get he alignment sorted my local one has the Hunter 4-wheel setup. I have a RRS1 on a 10 plate with 20" (it's the only time i can brag Rolling with laughter )
Also will i need to set the suspension on to tight tolerance while it's setup?
Thanks
Post #542864 Thu Dec 07 2017 3:44pm
Paddi
Kwik-Fit have such an awful reputation I wouldn't consider using them for anything other than perhaps a puncture repair.
Even then they would probably try to tell me that 'this tyre can't be repaired and you'll have to buy a new one - oh but its a 4x4 so of course you'll have to replace all four' and then 'oh dear, the only tyres we have in stock in that size are these Pirelli Super Xtortionatios at £300 a corner plus VAT and fitting.......'
Find somewhere else. And yes - a good alignment place will have the means to put your car into Tight Tolerance Mode.
Make sure the fuel tank is full. The alignment techs should use an airline with calibrated pressure gauge to set all 4 tyres to the correct pressures. Raise and lower the vehicle a couple of times then push it back and forth a bit to settle it down. Then check the ride height at each corner is within spec.THEN put the laser kit on and do a full alignment.
Chat them up a bit to show you're an enthusiast owner who looks after his car and get them to make sure all the readings are not just in the green zone but right in the middle of the green.
My local place does all of the above and my tyres are currently wearing perfectly evenly.
It helps I think if you make sure at least the wheels are clean and spotless and have it done on a dry day in the middle of the week. The techs will concentrate better if the car's not dripping on their heads whilst under it and Saturday is always the most hectic day so they are not in the best frame of mind to deal with fussy customers. 2008 MY Java Black TDV8 HSE
Post #542866 Thu Dec 07 2017 4:49pm
Tyrefitter
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
Here you go,,put your postcode in & it will give you a list of authorised Hunter places.
https://www.alignmycar.co.uk/
Andy. 2014 RRS SC santorino,coris roof.
2014 Evoque D-Lux Fuji
Previous motor.
2016 VW Amarok Highline,candy white
2014 RRS AB FUJI
2012 RRS Dynamic red edition Fuji
2012 RRS SE santorino
2015 Navara White
2008 RRS white TDV8
2007 RRS black TDV8
2002 RR Vogue
1996 P38 2.5 HSE.
Post #542867 Thu Dec 07 2017 5:31pm
PC76
Thx Andy & Paddi,
Will defo steer clear KF. Will have to be a weekend unless i go whilst off between Christmas and New year...
Post #542868 Thu Dec 07 2017 5:47pm
phillh
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
When I first got my car, it was pulling to the left. The dealer took it to kwik fit for me who had Hunter equipment, they improved it a bit but it still wasn't right.
After a couple of months, I took it to Discount Tyres in Luton, I had all 4 tyres replaced (budgets I'm afraid) and the Hunter 4 wheel alignment. They got it spot on, its like a new car now. Thumbs Up
Post #542871 Thu Dec 07 2017 6:02pm
Cymruambyth
Wales 2006 Range Rover Sport Supercharged HST Zermatt Silver
I wouldn`t go to KF for directions! Steve.
2006 Zermatt Silver, Range Rover Sport HST 4.2 Supercharged.
Post #542875 Thu Dec 07 2017 6:57pm
scousefly
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Are u 🤬🤬🤬
Mad??????? KF wouldn’t let them touch my mountain bike never mind my RR. If you ever utter those dirty words again I will hunt you down and sort you out Mr. Green Mr. Green Thumbs Up
Post #542885 Thu Dec 07 2017 9:52pm
PC76
I thought you were going to say Pinch my wheels then Scouse...😝
Post #542886 Thu Dec 07 2017 10:07pm
scousefly
tut tut
PC76 gender scarring at its utmost Mr. Green Mr. Green
Post #542890 Fri Dec 08 2017 12:42am
PC76
Hi Chapps,
Didn't get chance to get the alignment completed over Christmas and now need to do a run up to Oban next week so looking to get it sorted ASAP.
I used the link form Andy and have been getting quotes ranging from £95 to £140 with the most expensive stating the suspension should be on it's lowest setting and the cheapest stating they need it at least for half a day... so not had an overly confident feeling.
Can anyone tell me what they paid and what the official procedure is to set the alignment so i don't get sold up the river...
Post #545188 Mon Jan 08 2018 3:38pm
Tyrefitter
4 wheel alignment can take upto half day if bolts ect are seized.
Andy 2014 RRS SC santorino,coris roof.
Previous motor.
2014 RRS AB FUJI
2015 Navara White
2008 RRS white TDV8
2007 RRS black TDV8
2002 RR Vogue
1996 P38 2.5 HSE.
Post #545189 Mon Jan 08 2018 3:46pm
Tyrefitter
Previous motor.
2014 RRS AB FUJI
2015 Navara White
2008 RRS white TDV8
2007 RRS black TDV8
2002 RR Vogue
1996 P38 2.5 HSE.
Post #545191 Mon Jan 08 2018 3:53pm
Cymruambyth
Heard you first time Andy Laughing Steve.
Post #545192 Mon Jan 08 2018 3:54pm
PC76
Passing by your's tomorrow Steve... down to south Wales it's either the M6/M5 or down past Chester etc...
think i will need new rears shortly.....
Post #545193 Mon Jan 08 2018 3:59pm
Cymruambyth
If you`re passing near to Chester tomorrow, check this place out http://www.qrsport.com/ They did the Hunter alignment on my Focus ST (not a RR I know, but they seem to know their stuff) Thumbs Up Steve.
Post #545194 Mon Jan 08 2018 4:11pm
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
