Home > Technical > restricted performance plus engine management light
DSJ
red triangle came on when i accelerated fast from the junction with engine management light, can hear whistling noise from drivers side
have done the following so far as suggested by other members:
checked inlet manifold x 2 for cracks, no visual signs and no soot found under the engine cover
cleaned MAF sensor x 2, is it normal to find some sort of black liquid in sensor housing and associated hoses?
checked air filter - this was full of the black stuff mentioned above rather than dust
cleaned MAP sensor
checked inlet hoses
checked inter cooler hose near front wheel
after all the above the problem is still there, any advice on what to check next???
the below were the fault codes I got last time this happened in March - the issue resolved itself but has now come back again
P1247 - DTC definitions NOT found - refer to manual
P006A - MAP mass or volume air flow correlation
P0235 - Turbocharger/Supercharger Boost Sensor A Circuit
Post #544384 Sat Dec 30 2017 4:01pm
Disco_Mikey
Stuck actuator on the crossover valve Thumbs Up
There is a repair kit available, with a new actuator
Post #544401 Sat Dec 30 2017 7:25pm
DSJ
thank you for the reply.
can you elaborate slightly - is this actuator near the wheels arches or something else?
can this be done easily?
Post #544413 Sat Dec 30 2017 10:22pm
Disco_Mikey
Drivers front wheel arch, bottom of the radiator
Covered by a TSB, I'll try and find it tomorrow Thumbs Up
Post #544417 Sun Dec 31 2017 12:06am
DSJ
ok, thanks just been looking at the videos online
any ideas on below:
Post #544418 Sun Dec 31 2017 12:08am
Disco_Mikey
Wrong link Embarassed
Post #544572 Tue Jan 02 2018 12:39pm
Disco_Mikey
http://www.disco3.co.uk/gallery/albums/use..._TOPIx.pdf
Post #544573 Tue Jan 02 2018 12:41pm
DSJ
Mike
I have had the fault codes read and deleted by RAC.
I have also reached out for the actuator on the CSOV and lubricated it, when I retracted the arm I heard the audible clunk. There is corrosion evident on the pin.
The car seems to be ok now, but do not yet know whether the the oil back feed into air filter will continue.
The last time the codes were cleared, the vehicle was fine for approx 9 months.
So not sure whose intervention has sorted the issue???
Post #545173 Mon Jan 08 2018 12:48pm
Mihai77
Switzerland 2010 Range Rover Sport 3.0 TDV6 SE Bali Blue
for the same symptoms was told by LR dealer in Annemasse, France that turbocharger valve is corroded and needs replacement. Estimated cost of repair EUR 1,000. What do you thinK? 2010 Bali Blue, Reverse Camera, Winter Pack, Privacy Windows, Sunroof, Steel Tread Plates.
Post #545612 Fri Jan 12 2018 8:40am
