Home > General (L494) > Range to "oil service required" plummets |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1133 |
I have only just got pasted watching for the DEF to Start going down
Wed Jan 03 2018 8:25pm |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
This car must be female, it changes it's mind so often. Noticed the "service required" reminder had disappeared this morning, checked the "range to oil service" and it has gone up to 3500 miles!
Thu Jan 11 2018 9:13pm |
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 |
Have a read through the "Service Interval" and "Oil analysis " on this section of the DS forum
Fri Jan 12 2018 4:06pm |
Wow
Sun Jan 14 2018 8:05am |
Well, a software update (even though it had three last August to supposedly cure this issue) - to do with the instrument cluster I understand (waiting for the paperwork to see what it was).
Sat Jan 20 2018 9:43pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8800 |
From a quick flick through those threads, it appears that JLR's response is to update the diesel dilution algorithm so it doesn't flag up an oil change so often. Sounds like the same attitude from other issues - the engines will almost certainly survive to 3 years and then fall out of JLR's warranty responsibility and in to the hands of third parties. Third parties will, presumably, find ways to avoid paying for engine failures caused by oil dilution. The result: JLR owners left high and dry.
Sun Jan 21 2018 10:18am |
@RRSTDV8, you've got it spot on
Sun Jan 21 2018 8:47pm |
Update.
Wed Jan 24 2018 8:33pm |
SingeRRS Member Since: 22 Sep 2009 Location: Garage Posts: 127 |
Thousands - see https://www.discosportforums.co.uk/viewtopic.php?f=17&t=5379. More in D5 and Ewok forums.
Wed Jan 24 2018 11:00pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1231 |
And to think how many are out there that will only get serviced when indicated but don't reason with the accelerated count down, then they'll into the 2nd hand market in a few years with tired/compromised engines? Steve. 2006 2.7 TDV6 HSE in Cairns Blue. |
Thu Jan 25 2018 8:36am |
This is partly a consequence of the oil dilution and partly poor quality parts. Can affect all 2.0d Ingenium engines including RRS, Velar and Jags in addition to the DS
Thu Jan 25 2018 10:26am |
So - this morning I asked exactly how this dealer decided the oil did not need changing last week.
Thu Jan 25 2018 12:57pm |
@wilf
Thu Jan 25 2018 1:52pm |
It IS possible, but I don't care to contemplate that thought. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Thu Jan 25 2018 2:38pm |
