Home > Technical > Suspension query.
Cymruambyth
Wales
Suspension query.
Just a quickie. When I park at the top of my drive (fine down the bottom), the rear drivers side corner cocks it`s leg up. Now I know they sometimes auto level but where it`s parked is pretty level...if anything, there`s a very slight slope from driver to passenger side. Would it need calibrating after having a new compressor?
This is what it looks like...
 Steve.
Post #544062 Tue Dec 26 2017 2:21pm
Cymruambyth
Wales
 Steve.
Post #544380 Sat Dec 30 2017 1:12pm
I don't think it requires cal. after compressor replacement.
It might need cal. anyway though.
You should measure the heights
park on FLAT SURFACE.
go to off road height
go down to normal
switch eng off
leave door open
measure from the arch lip, to centre of wheel.
rear should be higher.
measure in mm (or cm)
Post #544392 Sat Dec 30 2017 5:44pm
Cymruambyth
Wales
I`ll try that cheers. It`s weird though, cos as soon as I unlock it, it goes back down and when I move it down the drive it sits ok! Not a major issue....I just like to know what`s going on Very Happy Steve.
Post #544450 Sun Dec 31 2017 3:14pm
Distance from centre of drive shaft to lip of wheel arch is 462mm front, 463mm rear. 2012 SDV6 - it's missing a couple of cylinders
Post #544463 Sun Dec 31 2017 7:07pm
Cymruambyth
Wales
1mm difference? Laughing Steve.
Post #544485 Sun Dec 31 2017 10:30pm
