Home > Faults & Fixes > Head rest DVDs |
are you playing the correct disc for the system? |
Fri Dec 29 2017 11:11am |
Wynne1991 Member Since: 28 Dec 2017 Location: Flintshire Posts: 11 |
This might be daft thing but what do you mean by correct disc ? I have only tried 1 disc and it is a genuine disc not a copy ! Thanks |
Fri Dec 29 2017 3:52pm |
Thats ok then as long as it's not a copy you trying to play try a hard reset disconnect the battery terminals from the battery and hold the positive and negative together away from the terminals you may need to put something metal between them just make sure there away from the battery itself it will reset the system so may work or the dvd may be broken |
Fri Dec 29 2017 8:49pm |
i assume you have used a cleaning disc on them |
Fri Dec 29 2017 8:51pm |
Ok thanks I wasn't sure how to do the hard reset , have got disc cleaner today will try tomorrow 👍 |
Fri Dec 29 2017 9:39pm |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 |
Silly question I know but I assume you are loading the CD in the rhs boot compartment and not the satnav unit under the passenger seat. |
Fri Dec 29 2017 10:34pm |
Load my into the player in the drivers side head rest |
Fri Dec 29 2017 10:37pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
Are the screens factory fitted ?
Fri Dec 29 2017 10:48pm |
As far as I'm aware yes it's a 05 I've on'y recently owned the car , the screen on drivers side opens up to load the disc and can control it off the screen or control panel on drivers side rear door panel |
Fri Dec 29 2017 10:52pm |
When you say control - can the rear entertainment be controlled from the same screen as your nav - radio etc ?
Fri Dec 29 2017 10:56pm |
My car is 05 and the dvd player (which I believe was factory fit) is in the little hatch on the RHS of the boot.
Fri Dec 29 2017 11:05pm |
I shall check tomorrow haven't even touched the screen in the front ! Thanks tho |
Fri Dec 29 2017 11:20pm |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
Mine is also an 05 and others have said the DVD player is hidden in the right hand side panel in the boot. Theres a small door and when you open it you can eject the multi disc dvd cassette.
Sat Dec 30 2017 12:40am |
Maybe mine aren't factory fitted as on the screen in the front I don't have the DVD or rear entertainment option |
Sat Dec 30 2017 9:06am |
