Home > General > What's the verdict on the RRS 2.7 TDV6?
CSC
As per the title, what is the consensus on the 2.7 TDV6?
Post #544102 Wed Dec 27 2017 12:35am
Petrol engines are more robust.
V6 diesels like to break in a bad way.
2007 models worst
Post #544105 Wed Dec 27 2017 7:23am
There's nothing wrong with the 2.7TDV6 so long as you don't want performance. It's a bit under powered for a vehicle weighing 2.5-3 tonnes. Having said that, plenty of people use them for towing and are happy with them.
The 2.7 needs it's belts changing at 7 years / 105k miles whichever is sooner. Plenty don't get them done on schedule it seems. There was a batch that had a redesigned oil pump casing. This was fine until the belts were changed but had a history of failing not long after. A better oil pump casing is available and should be used. If you're looking at one of the bad batch now, it should have had its belts done in the last two years or so. You can check the pump to see which one is fitted. Plenty of information by searching on here and disco3.co.uk.
Other than that, the 2.7 suffers the same suspension bush life as all RRS. Early 2.7 came with relatively small wheels. The steering rack was later modified to allow for wheels up to 20 inch. An early 2.7 with big wheels might have a tired steering rack. No RRS came with bigger than 20 in wheel until the RRS2 came out so any 21 or 22in rims are not standard. 2012 SDV6 - it's missing a couple of cylinders
Post #544109 Wed Dec 27 2017 8:57am
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
I bought (imported) a 2005 2.7 diesel in April this year and I love it. It had low mileage and had been sat still a long time. I splashed out and gave it a major service last month as I'm taking it with me to Portugal for good in a few weeks. Everything on the car works as it should. I simply love it and the help and advice on this site is great. Barrie.
2005 RRS 2.7TDV6 from 2017 -2024. Best car I ever had.
Current: 2018 Ford Ranger Wildtrak 3.2
Post #544114 Wed Dec 27 2017 9:31am
Disco_Mikey
Looked after correctly, they are fine
EGRs are Censored
Oil pumps are Censored
Allow for dealing with them as soon as you have bought the car
My replacement engine is now on 136k miles, and has not missed a beat Thumbs Up
Post #544118 Wed Dec 27 2017 10:26am
Pufftmw
My 2007 2.7 TDV6 has been very good and reliable, just touching 150k now, of which I've put on just under 60k. Serviced annually according to schedule.
Had the belts done on time, the EGRs blanked, a slight tune-up (still slow/sluggish but not as much as before) and I should get the oil pump done but keep forgetting.
Have had a bit of trouble with the MAF (replaced) and potentially one of the diesel pumps is faulty, though I've changed the diesel filter so will have to see if that sorts the issue.
Tows really well. Doesn't seem to make much difference to performance if you have nothing or 3t on the back. Just about to take mine for a 1k mile tow round UK/Ireland and I'm sure it'll be absolutely fine.
Post #544121 Wed Dec 27 2017 10:41am
Stevepd
We bought ours in May 1 owner with 36k and FLRSH. We're completely satisfied with, decent amount of torque and I use ours everyday. It's got everything we'd want and it's not thirsty at all. Everything works and the only fault I've had was by a 3rd party. I wouldn't disregard a 2.7 over a 3.0 but think more down to the car you're looking at.
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #544147 Wed Dec 27 2017 2:48pm
Johnpk47
United Kingdom 2008 Range Rover Sport TDV6 HSE Siberian Silver
Fantastic car and purchased in July on a 2008 plate. Have owned shoguns , land cruisers Mercedes ml etc and it’s the by far the best car I have owned. Have towed into France and it was faultless
Post #544166 Wed Dec 27 2017 6:39pm
BKHK
Australia
I had one for 3 years from 09 -12, no problems, performance was fine. The 2.7 is very smooth. Don’t discount it if you find a nice car.
Post #544193 Wed Dec 27 2017 11:38pm
Isn't the 2.7 also prone to breaking its crank? --
Post #544199 Thu Dec 28 2017 7:52am
Disco_Mikey
Less so than the 3.0...
Post #544201 Thu Dec 28 2017 8:34am
d-9
I test drove one, didn't feel that engine was appropriate for something with a badge saying 'Sport'. It actually felt dangerously slow pulling onto the dual carriageway on the test drive route.
Post #544216 Thu Dec 28 2017 10:51am
could have had a bad turbo, (or leaking pipe)
they have adequate performance if you select sport mode on the gearbox
Post #544220 Thu Dec 28 2017 11:00am
phillh
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
My 2005 TDV6 HSE has had egr's blanked and a remap and it is plenty quick enough for me.
Post #544240 Thu Dec 28 2017 1:12pm
Disco_Mikey
This Thumbs Up
Performance is adequate, but really should have had the 220bhp a remap gives, from the factory Thumbs Up
Post #544241 Thu Dec 28 2017 1:17pm
