Home > General > Brake Fluid Change |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4753 |
It's fairly normal that the brake fluid change is an extra when I used to take my jag to the dealer.
Sat Dec 23 2017 2:42pm |
When my 14 went in for its 3 year service they said it needed brake fluid changing,,I told them not to bother & when I got back home I checked it & it was in the green on my tester,so nothing wrong with it.
Sat Dec 23 2017 2:52pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1231 |
Andy,
Sat Dec 23 2017 3:34pm |
ChunkRRS Member Since: 20 Dec 2016 Location: Scottish Borders Posts: 154 |
No brake fluid changes included on a Land Rover service plan?
Sat Dec 23 2017 3:52pm |
You should check the terms and conditions on the service plan. I can't find the complete document online but the Land Rover website blurb says Service Plans cover the cost of ALL SCHEDULED SERVICING. If the service schedule requires a brake fluid change then it's black and white; the cost should be covered by the plan. Go on - kick up a fuss - you have been ripped off. 2008 MY Java Black TDV8 HSE |
Sat Dec 23 2017 4:09pm |
After reading this post I decided I wasn't having it, emailed my dealer and got an answer for you.
Sat Dec 23 2017 6:30pm |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
Is this the same for non service plan services, where I'd expect if it is on LR's 'to do' list then it would be done as part of that service? Or do dealers get to cherry pick what they want to do according to the price payed? And on this I'd be expecting that fluids whether brake fluid or oils were covered within the service price?
Sat Dec 23 2017 8:31pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4817 |
Extract from Service/Maintenance Sheet, note item No.9 asterisk get out clause. It's also stated in the Service History Book, this is for a RRS1 not sure about RRS2.
Sat Dec 23 2017 8:51pm |
This is like mine Steve. ChunkRRS,,you say the brake fluid change is covered under service plan.? When my14 went in for service in July They wanted to charge me around £80 to change it. Andy. Andy. 21 Ford Ranger Gone but not forgotten Focus RS Red Edition 2015 RRS AB Fuji. 2014 RRS SC Santorini 2016 VW Amarok 2014 RRS AB Fuji 2012 RRS Red Edition Fuji 2015 Nissan Navara 2012 RRS SE Santorini 2008 RRS White 2007 RRS Santorino |
Sun Dec 24 2017 8:56am |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 |
Just waiting for the day when they say that oil is a wear and tear item and therefore not part of the service plan. Merc C220 estate Sport AMG
Sun Dec 24 2017 9:31am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8800 |
Why do people insist on using LR dealerships for servicing? The plans are obviously a con as they work hard to charge for everything other than the oil and filter. The work done will doubtless be substandard too so they'll be doing bad things to your vehicle in the name of servicing.
Sun Dec 24 2017 3:26pm |
Of course you're right, an indie probably does perform a better service.
Sun Dec 24 2017 9:26pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4320 |
No better or worse than a full dealer history, it would seem |
Sun Dec 24 2017 11:00pm |
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 |
Was told brake fluid needs to be changed every 3 years and mine is due to be done. I only phoned up to book it for an MOT.
Sat Jan 20 2018 7:08am |
