Home > Maintenance & Modifications > Nottingham (Midlands) timing belt change |
amgmaj Member Since: 28 Nov 2017 Location: Nottingham Posts: 79 |
Anyone please ? |
Tue Dec 19 2017 9:43pm |
Bustanut Member Since: 19 Nov 2017 Location: Nottingham Posts: 71 |
Hi amgmaj, I haven’t used the, myself but knowles on the Epperstone bypass seem to be well regarded for Land Rover repairs and servicing. I plan to use them myself in the new year and spoke to them briefly on the phone. They seemed pretty knowledgeable.
Thu Dec 21 2017 6:46pm |
Hi mate
Thu Dec 21 2017 7:48pm |
amgmaj, thats even better. I'm only round the corner from them. I'm new to this 2 so not a fountain of knowledge yet. Been searching the forum for advice/troubleshooting tips etc. Only had mine a month to date.
Fri Dec 22 2017 1:35pm |
Definitely worth a call I'll be taking mine down there next year after the 8th January when they reopen.
Fri Dec 22 2017 1:43pm |
Its an HSE, Stornaway grey with ivory leather just done 50k with full stratstone history. I’m loving it at the moment and have added side steps and puddle lights to date. Also got a Mud guard set that I will fit over Christmas. It’s driving me mad that I haven’t given it a proper clean/detail yet but should get chance this weekend. It’s a nightmare keeping cars clean this time of year.
Fri Dec 22 2017 2:41pm |
Thats good colour to have, you can do loads to these cars with little things here and there and yes its a pain to keep the car clean in this weather but I do smile when I drive it
Fri Dec 22 2017 3:40pm |
Oh yes, that’s a beauty. I love the look of the tail pipes and bumper on the Autobiography. Have you had it lowered or is it at the lowest setting. |
Fri Dec 22 2017 4:01pm |
It must of been on the lowest height settings, I always wanted to get a factory fitted Autobiography kit it just finishes the RRS in my opinion
Fri Dec 22 2017 4:20pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 746 |
The indi I use won't change the belts, or at least yet, due to the rear HPFP pump being timed on the 3.0ltr. I understand that this allows the fuel to maintain a higher pressure at the common rail in response to the injectors opening. A timing pin is needed to be inserted to keep the timing while the belt is off, which makes it even harder as there is not a lot of room at the back of the engine. I think your quotes of about a grand are not too far off. I bought mine with the belts done because of that.
Fri Dec 22 2017 5:56pm |
Thanks for information Oldandconfused will keep that in mind when I book my car for change of belts, I'll mention that (timing pin is needed) to the Indi and see what he's says and price wise all seem to be similar not a big difference.
Sat Dec 23 2017 11:38am |
Good try, but I couldn't open the link (said it can't be found) thanks anyway There was a VIN range for the oil pump casing MY07's mainly. |
Sat Dec 23 2017 12:15pm |
Sorry mate try this one
Sat Dec 23 2017 12:46pm |
That one works thanks. It looks like it's refering to a sensor replacement, not addressing actual crankshaft failure. There are lots of threads on here and Disco3 sister site. Don't wish to worry you, but have a look. |
Sun Dec 24 2017 9:45am |
