Home > Maintenance & Modifications > Removing vents
Tyrefitter
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
Removing vents
Has anyone removed the bonnet/wing vents,I’m wanting to get mine colour coded but not sure if they just clip on,I don’t want to damage them while removing,,thanks in advance
Andy Andy.
2014 RRS SC santorino,coris roof.
2014 Evoque D-Lux Fuji
Previous motor.
2016 VW Amarok Highline,candy white
2014 RRS AB FUJI
2012 RRS Dynamic red edition Fuji
2012 RRS SE santorino
2015 Navara White
2008 RRS white TDV8
2007 RRS black TDV8
2002 RR Vogue
1996 P38 2.5 HSE.
Post #543815 Thu Dec 21 2017 2:55pm
phillh
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
Andy,
They pull off quite easily on 1st gen cars, see video
Post #543816 Thu Dec 21 2017 3:27pm
Tyrefitter
Mines a RRS2,,don’t want to pull them like that if they are screwed anywhere
Andy Andy.
Previous motor.
2014 RRS AB FUJI
2015 Navara White
2008 RRS white TDV8
2007 RRS black TDV8
2002 RR Vogue
1996 P38 2.5 HSE.
Post #543817 Thu Dec 21 2017 3:34pm
phillh
If you look at some on the ones on ebay, you can see the retaining tabs and clips.
Post #543818 Thu Dec 21 2017 3:41pm
Eaters
Andy, I replaced my 2008 with chrome ones. The instructions were to use a sharp upward and outward pull to release them as they are only held in by clips. But I still managed to break a couple of clips on one of mine! Didn’t matter to me as I was replacing them. In your case extra care needed.
Th guide from Powerful UK below seems to show that they are easier on the 2010 and later RRS
This may also help in that you can see and understand where the retaining clips are Robin
Awaiting rebuild: NGTF
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #543819 Thu Dec 21 2017 3:50pm
Tim in Scotland
RRS2 L494 are a different design and a lot smaller - Andy have you searched YouTube for any PowerfulUK videos? It’s dark outside now so photos done with a Petzel Headlight
On L494 on the inner wing there is a torqz type bolt just behind the rear of the two air intakes and just in front of the foam of the bonnet seal - not sure sure if removing this single bolt on each side doesn’t let you slide out the vent.
In this photo I mean the left hand bolt - the right hand one is for the air intakes
 2018 Melting Silver Mini Countryman PHEV - a test car before Seeing if I could go to totally Petrol/Diesel free motoring
Post #543825 Thu Dec 21 2017 6:04pm
Can't be certain, but can't see any screw fixings I thing the two pegs each end in the top picture are locating lugs, but may be screws from underneath as not sure what is directly under the bonnet vent, looking at Tim's Picture may be another grille screwed in place, but they do look like they are retained by the same style of spring clip that holds most of the dash trim in place as well, the one's that disappear in to oblivion when a piece of trim is pulled off. Laughing Doesn't appear to show any retaining clip or screw in the part's list either.
Personally I think I might have tried getting some secondhand one's and have them colour coded ready to swap over. also that way you could work out how they are attached, then sell the originals on. Only a suggestion.
Post #543829 Thu Dec 21 2017 8:30pm
The vent with screw in Tim's photo is the "Queen Mary funnel" vent that feeds the airbox. The side wing and bonnet top "vents" are just plastic trim pieces that serve no purpose other than cheap styling. 2012 SDV6 - it's missing a couple of cylinders
Post #543841 Thu Dec 21 2017 11:39pm
Tim in Scotland
The “Queen Mary” air intakes are also why L494 cannot be fitted with a Raised Air Intake or even a snorkel, the clamshell bonnet and the increased wading depth of L494 is supposed to be sufficient that the car would float anyway if you went in any deeper.......... and i’m Not volunteering to test it to see if it is enough...... 2018 Melting Silver Mini Countryman PHEV - a test car before Seeing if I could go to totally Petrol/Diesel free motoring
Post #543845 Fri Dec 22 2017 12:07am
Not sure I would describe it as cheap styling Wayne, expensive bit's of plastic at around £800.00 for four pieces at L/R prices. Rolling with laughter
Post #543848 Fri Dec 22 2017 1:08am
PEACHY
Have you seen this yet - I looked on topix & it recommended fitting new clips Wink
http://accessories-instructions.landrover....7105312216 14MY Autobiography Dynamic - SDV6 - Fuji White Smile
Post #543852 Fri Dec 22 2017 6:35am
Tyrefitter
Thanks guys for all the reply’s,I may see if I can get a pair off eBay & paint them first like Col says.
Andy. Andy.
Previous motor.
2014 RRS AB FUJI
2015 Navara White
2008 RRS white TDV8
2007 RRS black TDV8
2002 RR Vogue
1996 P38 2.5 HSE.
Post #543856 Fri Dec 22 2017 8:37am
Shocked Shocked Shocked No, not cheap!
How about "tacky"? Whistle Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #543858 Fri Dec 22 2017 8:46am
