Home > Technical > Best CTEK Charger to buy for RRS |
warkman Member Since: 28 Feb 2015 Location: Warwickshire Posts: 234 |
Now faound a MXS7 cheaper..
Sun Dec 17 2017 3:51pm |
Sun Dec 17 2017 4:22pm |
I find tow bar electrics is the easiest way to connect and charge 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Sun Dec 17 2017 4:28pm |
Unfortunately, my tow bar electrics are only 5 pin, not the 7 pin on younger models Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4 |
Sun Dec 17 2017 4:32pm |
5 pin.? Never seen those,they are either 7 pin or 13 pin.
Sun Dec 17 2017 4:43pm |
Sorry, you are right, 7 pin π Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4 |
Sun Dec 17 2017 4:58pm |
Can use some 7pin as long as its not the one with black flap on it. Have a look in the forum shop as there is more info regarding 7 pin charging 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Sun Dec 17 2017 5:28pm |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
Sorry to hijack, I assume towbar electrics were an option? Steve. |
Sun Dec 17 2017 5:32pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4777 |
yeap towbar electrics were option.
Sun Dec 17 2017 6:11pm |
Sun Dec 17 2017 6:26pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4833 |
MXS7 or MXS10 they have the advantage of having a separate 12 volt power supply should you need it to retain memory on a vehicle etc.
Sun Dec 17 2017 9:29pm |
Just ordered the MXS7 with extension lead and battery connectors.
Sun Dec 17 2017 11:08pm |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 389 |
I have 3 C-Tek MXS-5 units and I find the mode switch becomes unresponsive after a while from new. They work but the mode switch does not seem to change the setting until it has been pressed a few times. The issue is the same for all 3 units I have. When they are new they responded instantly. I would go for the MXS-7 as I find the MXS-5 a bit undersized for the RRS battery. |
Mon Dec 18 2017 5:27am |
Where does your comfort connection come out? Canβt quite fathom it π Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4 |
Tue Dec 19 2017 7:14pm |
