Home > Maintenance & Modifications > RAI Anybody tried these? |
qcnr Member Since: 07 Dec 2017 Location: Stavanger Posts: 40 |
I realise it isnΒ΄t a full blown sealed snorkel, but could do the job in an accidental dip...
Fri Dec 08 2017 10:37am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
Looks basically the same as a factory RAI and has the same limitations.
Fri Dec 08 2017 11:01am |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
What are the limitations? It must cause mpg to drop. cheers Hugh |
Fri Dec 08 2017 2:54pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8800 |
Limitation is that it is not a snorkel (as they suggest). It is a raised inlet intended to pull in clean air instead of dusty air. The device isn't water proof. Even if the device itself is waterproof, the hose within the vehicle's wing isn't and so water can get in.
Fri Dec 08 2017 6:55pm |
Whats MPG 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black 2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18β Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning π |
Fri Dec 08 2017 7:04pm |
I'll manage without one then. Thanks. |
Sat Dec 09 2017 7:09am |
"milliseconds per gallon" |
