Home > Faults & Fixes > steering wheel vibrating but tracking and alignment done
craigdunne
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Bonatti Grey
Hi Guys,
i have a Nov 2009 RRS HSE TDV8 and when i drive over 65 the steering wheel vibrates terribly. i took it to the place i bought it and they did the tracking and laser wheel alignment but when i drove it away it was still the same. Does anyone know if its anything more sinister? the wheels are 22 inch revere so not original, dont know if that could be a reason.
Your help is much appreciated.
Post #542759 Wed Dec 06 2017 10:19am
LJRH
Could be tyre pressures- I have had that fault. Also could be your tyres don’t match, ie tread patterns Noisy black one
Post #542761 Wed Dec 06 2017 11:12am
Cymruambyth
Wales
Balancing? I have this with my 22`s but haven`t had it looked at yet. Steve.
Post #542762 Wed Dec 06 2017 11:29am
Tyrefitter
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
sounds like you have a wheel or 2 out of balance.
Andy Andy.
2014 RRS SC santorino,coris roof.
2014 Evoque D-Lux Fuji
Previous motor.
2016 VW Amarok Highline,candy white
2014 RRS AB FUJI
2012 RRS Dynamic red edition Fuji
2012 RRS SE santorino
2015 Navara White
Subaru wrx sti widetrack
2008 RRS white TDV8
2007 RRS black TDV8
2002 RR Vogue
1996 P38 2.5 HSE.
Post #542764 Wed Dec 06 2017 11:32am
wings21660
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Fuji White
I had this on MY11 Autobiography turned out to be warped hubs
Post #542768 Wed Dec 06 2017 12:45pm
gogsy1956
Had this on my 22's, took the email to everyone balanced but found that the 2 fronts were slightly oval. Managed to get them squeezed back into shape and all's been fine since 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #542772 Wed Dec 06 2017 2:38pm
gogsy1956
Don't even ask what I was talking about in the previous post Rolling with laughter 2010 RRS, TDV8
22" overfinch
Post #542773 Wed Dec 06 2017 2:39pm
craigdunne
Thanks guys for your reply. I had the tracking done but still the same. he did mention the wheels didn't sit right on the hub so maybe that's the problem. i will explore more.
Post #544789 Thu Jan 04 2018 3:02pm
Paddi
Do you know exactly what he meant by this?
Could be the wheels need spigot rings fitted. Have a look at this:
https://www.spigotrings.com/index.php?route=common/home
OR, I'm sure in the past a couple of owners have had apparently inexplicable vibration and it turned out to be water inside the tyres.
Poorly maintained compressors can put water in your tyres when you top them up. 2008 MY Java Black TDV8 HSE
Post #544791 Thu Jan 04 2018 3:20pm
Stevepd
Get the wheel balancing checked like Andy says, quick and easy to eliminate. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #544800 Thu Jan 04 2018 4:05pm
Ferret15
United Kingdom 2008 Range Rover Sport TDV8 HSE Sumatra Black
I had this on my 22 which came on the rrs 08 when I brought it. Two ended up having small cracks in them. I’ve since gone down to the 20s and the difference in ride comfort and noise is incredible.
Post #545023 Sun Jan 07 2018 10:29am
d-9
I had this issue on my tdv8, it was warped brake discs. Does it vibrate worse under braking?
Ditch the 22s anyway, ride is bad enough on 20s!
Post #545026 Sun Jan 07 2018 10:52am
daxmatt
have you ever used tyre weld,,this can put them out of balance
Post #545028 Sun Jan 07 2018 10:57am
Ferret15
I was amazed at the difference from 22 down to 20s. But if you says it’s bad enough on 20s then I think I maybe tempted to change again. When is the best size to be on?
Post #545031 Sun Jan 07 2018 11:54am
geoffsnook
You cant go much less than 20's as i assume you have brembo front breaks so i think some 19's fit but you need to check or you can use a 45 series tyre which will improve the ride a bit Thumbs Up
Post #545036 Sun Jan 07 2018 1:13pm
