Home > General (L494) > Can anyone identify this cable?
MrM
Does any knowledgeable folk know what this is? Cable circled in white.
And in the second picture, the rubber cable sleeve is pressing against the rubber boot seal, presumably due to the angle and positioning of a wire inside. Looks like some tape has been applied to it, so not sure if I should expect some problems from this in the future?
Thanks!
Post #542751 Wed Dec 06 2017 9:44am
SVR575
picture?? SVR 2018 in Santorini Black.
Post #542753 Wed Dec 06 2017 10:10am
Paddi
 2008 MY Java Black TDV8 HSE
Post #542754 Wed Dec 06 2017 10:26am
MrM
Sorry, was in my gallery, thought it would show in the main page.
Post #542756 Wed Dec 06 2017 10:29am
hafman
Re: Can anyone identify this cable?
I had the same issue and was concerned it might either damage a cable or compromise the weather sealing; I had it rectified under warranty without issue or resistance from the dealer.
Post #542786 Wed Dec 06 2017 6:17pm
udash
2013 Range Rover Sport SDV6 Autobiography Firenze Red
From the second photo, it seems like you already have the fix to prevent the cable catching the seal but has failed to work. Mine had the problem and it was fixed under warranty by simple plastic clip to keep the cable away (which is visible on the photo).
Post #542840 Thu Dec 07 2017 9:44am
MrM
Interesting. Thanks.
Post #542841 Thu Dec 07 2017 9:59am
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
