Home > Technical > christmas tree lights |
Ade99 Member Since: 28 May 2014 Location: wombourne Posts: 19 |
Hi all
Sun Dec 03 2017 5:49pm |
You do need to get the codes done but does sound like maybe the alternator is maybe om its way out |
Sun Dec 03 2017 6:01pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
I would support the thought that it is more than just the alternator. I drove mine for 16 miles on a brand new fully charged battery but with no alternator charge (not intentionally) and it only stopped when the battery went flat.
Sun Dec 03 2017 11:47pm |
Thanks for the replys is the brake switch under the brake pedal or located somewhere else? |
Mon Dec 04 2017 8:21am |
Here, this may help (I've not changed one myself):
Mon Dec 04 2017 8:47am |
Ste815l Member Since: 22 Sep 2017 Location: Newcastle Posts: 30 |
Yes it's located behind brake pedal only a £10 part. Try using some wd40 or electrical spray on the switch as they can get gummy and stick. But signs of this will be brake lights constantly on. |
Mon Dec 04 2017 8:48am |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
For what they cost and the time the part takes to change, it’s worth going ahead and replacing it. It is also worthwhile carrying a spare in your glovebox.
Mon Dec 04 2017 9:39am |
Hamtheman Member Since: 18 Jan 2017 Location: Joburg Posts: 33 |
I had a similar issue , the cause was found to be loose battery terminals due to some serious gravel roads, nipped them up and all good. |
Mon Dec 04 2017 10:55am |
Thanks for the advice going to check the battery tonight and put it on charge and have a look at the brake switch and lights and try to start it tomorrow after the battery has had a good charge |
Mon Dec 04 2017 12:16pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8800 |
Check for loose earth connection points too. There are a few dotted about with about 5 in the engine bay. A loose one can cause issues. 2012 SDV6 - it's missing a couple of cylinders
Mon Dec 04 2017 2:38pm |
Thanks for all the great response looks like I have a lot to check.
Mon Dec 04 2017 9:01pm |
Had a busy day today and just the sort of weather to be outside messing with the car.
Sat Dec 09 2017 5:16pm |
Well done Ade. Hope the good news continues.
Sat Dec 09 2017 5:33pm |
