Home > Maintenance & Modifications > Windscreen washer jets |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 389 |
The under bonnet sound deadening pad is fairly easy to remove which I did recently to install Dynamat sound proofing. I suggest you use a V notch plastic trim removal device to extract the Christmas tree clips. The pad needs to be fully supported as you remove the last few clips as it is likely to bend in half if you don't and damage the material. Two people job.
Tue Dec 12 2017 4:52am |
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 |
Just had the brake discs snd pads chsnged. Then in for a mot. After that washer jets suddenly working. 2019 RRS P400e Autobiography
Thu Jan 25 2018 5:10pm |
I will watch this thread as my passenger side one does not work very well |
Thu Jan 25 2018 6:23pm |
