Home > Technical > Another What battery thread.
Oldandconfused
I think that the cold spell has revealed that my battery is past it's best. It's a LR branded (Varta) YDG500130, but I cant see any date stamp so have no idea how old it is. It would appear to be OEM and a lead acid. If it's the original it's done well at 7yrs old, which is feasible going from my last D3.
I am considering staying with lead acid rather than AGM and from a search on here, this looks like it should do the job;
https://www.tayna.co.uk/EA1000-Exide-Premi...7488.html.
It says 017TE, L-353mm W-175mm H-190mm which from what I can tell will fit.
Unless anyone has any alternative suggestions.
Thanks.
Post #542416 Sat Dec 02 2017 11:38am
Tim in Scotland
I replaced my Defender’s battery last year - it was 20 years old after all and I had it on a conditioner or solar charger when the vehicle was not going to be used for long periods. I was advised to go for a battery with the highest CCA - cold cranking Amps - when I replaced it. Fitting a high CCA battery has transformed cold weather starting. They are available in standard form lead acid batteries as well as AGM batteries and are no bigger than a normal battery in size. 2018 Melting Silver Mini Countryman PHEV - a test car before Seeing if I could go to totally Petrol/Diesel free motoring
Post #542424 Sat Dec 02 2017 12:29pm
Oldandconfused
Got you. The Amp/hour is higher, but the CCA is actually 50 less then, although the LR fitted says SAE and the Exide measures it in EN. Looks like I need to do some more research. Many thanks.
OK, 950 SAE is the same as 900 EN according to google Thumbs Up
Just wondering if it's worth looking for something with a few more CCA. Living in the East of England, we don't seem to have too many really cold mornings,and I only have to get going early once a week.
Post #542432 Sat Dec 02 2017 1:42pm
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
