Home > Faults & Fixes > Tdv8 fault code suspension and gearbox fault |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
Just had some issues with mine. Flat battery turned out to be a duff alternator. So a brand new battery went flat in a short whil.
Sun Nov 26 2017 11:47pm |
Davidtdv8 Member Since: 18 Jun 2017 Location: Leeds Posts: 7 |
A will get my optimiser on the battery today and see if that works cheers |
Mon Nov 27 2017 9:00am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4333 |
You need the fault codes from all the modules |
Mon Nov 27 2017 9:29am |
Been in to local Range Rover Indy and it’s something to do with the Rear e diff motor or diff mechanism will post more when repaired |
Wed Dec 06 2017 4:09pm |
Hocks172 Member Since: 01 Dec 2016 Location: Brighton Posts: 83 |
Ive had to change the actuator on my e-diff, so could be that? does it grind every now and again? Tesla model 3 long range
Wed Dec 06 2017 8:12pm |
Ye was grinding now and again but then put all sorts of light on dash but had motor changed and all good again now |
Wed Dec 06 2017 8:13pm |
Wed Dec 06 2017 8:31pm |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 |
Do all TDV8s have the e-diff 61 AB 5.0 supercharged rocket
Wed Dec 06 2017 8:57pm |
A don’t think so mines the tdv8 hst and has e diff don’t know how to tell |
Wed Dec 06 2017 8:58pm |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
No, there’s no e diff on my car |
Wed Dec 06 2017 9:07pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8840 |
Most TDV8s don't have the e-diff. Indeed, I would say less than 1% of all RRS1 have e-diff. It's as rare as a rare thing. 2012 SDV6 - it's missing a couple of cylinders
Wed Dec 06 2017 9:41pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4840 |
I think it was only the HST that had the e-diff standard, otherwise it was a paid option. Without getting under the car to look is there anything on the 4x4 screen on the HST version to indicate it might be fitted ?..
Wed Dec 06 2017 9:47pm |
From what a was seen if you turn the rotary nob in center to far right position mud ruts a think on screen in 4x4 screen it comes up with a padlock on the pic of the Rear diff |
Wed Dec 06 2017 9:53pm |
Mine shows that on rock crawl center to locks 61 AB 5.0 supercharged rocket
Wed Dec 06 2017 10:23pm |
