Home > Faults & Fixes > Tdv8 fault code suspension and gearbox fault
Davidtdv8
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
2008 tdv8 hat Was fine and driving fine this morning then went to go out this afternoon and dash lit up like a Christmas tree so scanned with snap on solus and got codes
U0416
U0403
U0421
Been told battery, brake light switch but battery’s only 6 months old
I also think I have a problem with the Rear diff motor now and again
Dose any one know what it could possibly be before it goes in to dealer
Post #541905 Sun Nov 26 2017 11:10pm
Eaters
Just had some issues with mine. Flat battery turned out to be a duff alternator. So a brand new battery went flat in a short whil.
I suggest you check your battery voltage checked and also check for a good charge from the alternator. Both easy tests (Green Flag did mine) to eliminate those issues as the symptoms you describe mirror what I had although I can’t speak for the codes you mention.
See here for more info
http://www.rrsport.co.uk/forum/topic49170.html Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #541910 Sun Nov 26 2017 11:47pm
Davidtdv8
A will get my optimiser on the battery today and see if that works cheers
Post #541916 Mon Nov 27 2017 9:00am
Disco_Mikey
You need the fault codes from all the modules Thumbs Up
Post #541918 Mon Nov 27 2017 9:29am
Davidtdv8
Tdv8
Been in to local Range Rover Indy and it’s something to do with the Rear e diff motor or diff mechanism will post more when repaired
Post #542775 Wed Dec 06 2017 4:09pm
Hocks172
Ive had to change the actuator on my e-diff, so could be that? does it grind every now and again? Tesla model 3 long range
BMW f15 X5 m50d SOLD!
Disco 5 HSE Lux SOLD!
Evoque Dynamic Lux. SOLD!
RRS HST Sold!
Other gonners, Disco 3, BMW 525d E60, Jag 2.2d X-Type, Merc E240, Audi A4, Peugeot 306, VW Golf GTI 1.8T mk4,Toyota Hilux, Mazda 323f, Escort 1.3!
Post #542798 Wed Dec 06 2017 8:12pm
Davidtdv8
Ye was grinding now and again but then put all sorts of light on dash but had motor changed and all good again now
Post #542799 Wed Dec 06 2017 8:13pm
Hocks172
Thumbs Up Tesla model 3 long range
RRS HST Sold!
Post #542802 Wed Dec 06 2017 8:31pm
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
Do all TDV8s have the e-diff 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #542805 Wed Dec 06 2017 8:57pm
Davidtdv8
A don’t think so mines the tdv8 hst and has e diff don’t know how to tell
Post #542806 Wed Dec 06 2017 8:58pm
GodivaNige
No, there’s no e diff on my car
Post #542807 Wed Dec 06 2017 9:07pm
Most TDV8s don't have the e-diff. Indeed, I would say less than 1% of all RRS1 have e-diff. It's as rare as a rare thing. 2012 SDV6 - it's missing a couple of cylinders
Post #542812 Wed Dec 06 2017 9:41pm
I think it was only the HST that had the e-diff standard, otherwise it was a paid option. Without getting under the car to look is there anything on the 4x4 screen on the HST version to indicate it might be fitted ?..
Post #542815 Wed Dec 06 2017 9:47pm
Davidtdv8
From what a was seen if you turn the rotary nob in center to far right position mud ruts a think on screen in 4x4 screen it comes up with a padlock on the pic of the Rear diff
Post #542817 Wed Dec 06 2017 9:53pm
ShooterNeil
Mine shows that on rock crawl center to locks 61 AB 5.0 supercharged rocket
Post #542820 Wed Dec 06 2017 10:23pm
