Home > Wheels & Tyres > New RRS owner. need wheel advice |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8828 |
The 19 will be ok if it's 255/55/19 as that is very close to the 275/45/20. 255/50/19 is a bit small. It won't wind up a diff as such but it might annoy the stability control system enough to make it intervene at times.
Sun Nov 12 2017 11:35pm |
ODAK Member Since: 08 Nov 2017 Location: EXMOOR Posts: 2 |
Thanks TDV8. I will check this out. mind you deposit paid and so its had belts done and new gearbox oil/filter pan. etc
Sun Nov 12 2017 11:52pm |
Mani Member Since: 18 Jun 2016 Location: Uxbridge Posts: 298 |
Hi Pal just let you know having different wheel sizes on a single axel, not only is it illegal and can earn you 3 points , but should you be involved in an accident your insurance will be null and void! So please be very careful and also MOT Failure
Mon Nov 13 2017 12:09am |
Except in the case of the emergency spare wheel which is often a different size and also speed and distance limited for use. One of the legal quirks with wheel sizes. The rest of your statement is correct if used as normal wheel. John
Mon Nov 13 2017 12:15am |
MY08 RR SPORT3.6TD V8 FULLY LOADED, COOLER BOX, GVIF UNIT, PIONEER AVIC-F980DAB HEAD UNIT, RETAINING 4X4 INFO OEM SCREEN AND TS-WX130DA SUB
Mon Nov 13 2017 12:21am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4833 |
A LR008548 wheel rim now a LR027544 will certainly fit a 06 plate car, and with a 275/45 x 20 tyre it will also fit up into the spare well O.K. with no problems. Cheers Col |
Mon Nov 13 2017 1:56am |
