Home > Maintenance & Modifications > 2012 need Adblue |
Definitely not 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Thu Nov 09 2017 9:46pm |
rjbrocklesby Member Since: 04 Nov 2017 Location: Lincolnshire Posts: 25 |
Thanks for that.
Thu Nov 09 2017 9:48pm |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 192 |
Should have, in the instrument menu you can select it. 2018 Telsa MS
Thu Nov 09 2017 11:05pm |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 |
My car is a MY2012 and has auto high beam, here's a picture of the headlight switch selected to auto, check yours to see if you have the same. |
Thu Nov 09 2017 11:19pm |
Mine does have an auto setting on the headlight switch so the lights come on and off when it gets dark. The high beam doesn't automatically come on though, so I presume there is a setting I need to do on the control panel as per Puslinch's post.
Thu Nov 09 2017 11:24pm |
The auto high beam on/ off is an option and not standard, the Auto on light switch is purely to turn on/off as required.
Thu Nov 09 2017 11:46pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4834 |
If you are referring to High Beam Assist, it can be turned on and off via the menu accessed through the R/H menu switch on the steering wheel Vehicle Set-up option, standard on A/B's option on other models. Should also be able to see sensor in interior mirror if I remember correctly. From outside off course.
Thu Nov 09 2017 11:49pm |
