Home > Faults & Fixes > Veru Strange Noise.
crdixon2004
United Kingdom 2008 Range Rover Sport TDV8 HST Stornoway Grey
Veru Strange Noise.
Hi all.
New to the forum. Had a read of afew posts but cant find anything in relation to my problem. Lol
I have a 2008 3.6tdv8. Everything working fine up until the oil is at optimum temperature and accelerating past 50mph. A squeaking noise begins. This is only on acceleration and hard acceleration or going up hill. Also this only happens when the oil it at temperature.
Had a couple of people say turbos etc. But i was baffelled as it only happens when oil is at temperature and accelerating plus only over 50mph. Surely it would happen all the time if it was turbos?
Any info will be greatly appreciated.
Also lile to add i have no loss of power at all.
Post #540406 Thu Nov 09 2017 11:18am
A squeak or a constant noise like a whistle?
When you say oil temp, do you just mean temp on the dash?
Is there any black smoke related to this?
I wonder if it's an EGR actuator if it's temp related. The EGRs don't open until the engine is up to temp. They obviously close when you accelerate but a problem with an EGR (or turbo) should throw an error code and / or have a performance hit. 2012 SDV6 - it's missing a couple of cylinders
Post #540415 Thu Nov 09 2017 1:38pm
crdixon2004
Hi. Yes when the gauge is at temperature the noise when accelerating starts all the wag through acceleration. Its the sound of like at alternator belt when cars are started on a morning and its slipping. But i know its not that because its only when i accelerate and then it only starts above 50. Once started it happens all the time until i slow right down around town then only on hard acceleration it starts again.
Hope its an easy fix lol
Post #540417 Thu Nov 09 2017 2:06pm
crdixon2004
Also there are no faults. I have had it into a garage and i firstly expected a hose but they cant see anything and just suspected the turbo straight away. But i prefer a different option before having to go down that route.
Post #540418 Thu Nov 09 2017 2:11pm
Camelrock
You say at over 50mph does it seem to be engine or drive related ? Reason I ask is I had similar noticed it on hills like Sutton bank then I changed the torque converter earlier this year and haven't heard the noise since 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
2016 Discovery Sport HSE
1994 Dakar current
Post #540421 Thu Nov 09 2017 2:28pm
crdixon2004
Only when i accelerate on the drivers side. When i am not accelerating there is no noise at all.
Post #540423 Thu Nov 09 2017 2:37pm
Camelrock
The TDV8's are known for warping the exhaust manifolds and snapping the studs could be that as the exhaust expands when warm 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #540424 Thu Nov 09 2017 2:44pm
crdixon2004
Ah great so manifold replacement? Or amd new exhaust sytem. Lol ??
Post #540426 Thu Nov 09 2017 2:51pm
crdixon2004
Thinking about it though wouldnt it happen everytime i accelerate if it was coming from the manifold?
The sound is like when you blow up a balloon and let the air out by pulling the end to make the squeak noise.
It isnt affecting the performance of the car. It is one of those noises that if i keep going is it going to just go bang. Lol
Post #540433 Thu Nov 09 2017 3:37pm
Camelrock
As I understand it it's a body off job though this is only what I've read on here . Try looking it up by the search icon 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #540435 Thu Nov 09 2017 3:43pm
Camelrock
IT was always at the back of my mind was a turbo going to let go but 2 years and 20000 miles later as I say seemed to go after I changed the torque converter maybe just a coincidence did have the exhaust off might be worth checking the flange bolts as the fasten directly onto the turbo could be blowing on the offside 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #540438 Thu Nov 09 2017 4:20pm
crdixon2004
Ok mate thanks.
Just been to a LR specialist and he said it is almost like the water pump has gone. Reason being that obv it is only happeng when its at temperature. Worth a try first i suppose.
Post #540443 Thu Nov 09 2017 5:43pm
crdixon2004
Also i have notoced the coolant disappearing so topped it up and then i will see. Hope it is the water pump and nothing serious.
Just confusing it only happening at temperature and when i accelerate.
Post #540448 Thu Nov 09 2017 6:37pm
The exhaust manifolds are body off and they are also about £600 each. Annoyingly, the manifolds on the FFRR can't be used but they are a fraction of the price. 2012 SDV6 - it's missing a couple of cylinders
Post #540466 Thu Nov 09 2017 8:45pm
crdixon2004
Water pump chsnge an easy job?
Post #540503 Fri Nov 10 2017 8:24am
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
