Home > In Car Electronics > Head unit and nav |
Fri Oct 06 2017 3:34pm |
Try mmj on here they are breakers who sponsor this site go for second hand from them if they have one or another breaker unless you have a wad of cash burning a hole in your pocket is it logik 7 or just normal Harmon Kardon |
Thu Nov 09 2017 6:58pm |
Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163 |
Normal |
Thu Nov 09 2017 7:03pm |
You should be able just to buy one and change it over but to be sure if its not working take it out and check the number to be sure but i am pretty sure they are all the same as long as its just Harmon Kardon |
Thu Nov 09 2017 7:07pm |
I’ve noticed a couple different model numbers on eBay so I’ll remove to check mine
Thu Nov 09 2017 7:09pm |
There not hard to get out but make sure the people on ebay accept returns mmj are on there as well |
Thu Nov 09 2017 7:12pm |
Amp arrived today fitted but not working fault code now is
Tue Nov 14 2017 6:36pm |
I spoke to rangerover dealer today they told me amplifiers are coded to the car so second hand amp won’t work in my car
Wed Nov 15 2017 7:00pm |
Second amp arrived today same problem fibre optic failure
Tue Nov 21 2017 9:44pm |
It may be the tmc part itself unless the fuse is blown then there should be power there unless you are unlucky enough to have a break in the wire |
Wed Nov 22 2017 4:01pm |
Just tested power lead all ok so unit needs replacing
Wed Nov 22 2017 5:47pm |
Wed Nov 22 2017 7:08pm |
I managed to buy a used TMC from eBay for £21 delivered now all sorted
Fri Nov 24 2017 9:17pm |
And how much and what sis the stealers say |
Sat Nov 25 2017 4:49am |
