Home > Technical > How do i replace lock on detacable towbar? |
Mani Member Since: 18 Jun 2016 Location: Uxbridge Posts: 298 |
Hi Folks, looks like I am not having much luck with keys at the moment
Mon Nov 06 2017 6:51pm |
Wait till new lock arrives and it should have instructions with it |
Mon Nov 06 2017 7:11pm |
Thanks Geoff, it should be with me on Wed I hope
Mon Nov 06 2017 7:16pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4835 |
Easy enough to replace, small pin punch and a hammer little more difficult if key broken in locked position. Be careful not to break the Red plastic ratchet part behind the Knob as this bit is not available separate from L/R or never used to be, and does not come with new lock.
Mon Nov 06 2017 9:06pm |
Thanks Col
Mon Nov 06 2017 11:52pm |
Hi Folks just received brand new replacement Original tow bar lock Part No: KNW500010 WITH 2 keys from Duckswoth Land Rover, I Thought I had ordered it from RimmerBros, anyway they did not send any instructions in the box, just wondering if anyone can PM me to try and explain to me as guide how I would remove the old lock with a broken key in the unlocked position?
Thu Nov 09 2017 2:48pm |
Thanks ShooterNeil,
Thu Nov 09 2017 11:48pm |
Give Ducksworth a ring and I’m sure he will email copy instructions or post leaflet if meant to be supplied. John
Thu Nov 09 2017 11:54pm |
PM sent, it really is very simple.
Fri Nov 10 2017 12:01am |
Thanks to both Col and Johnski
Fri Nov 10 2017 12:06am |
Fri Nov 10 2017 12:09pm |
I Will Never Do, Trust Me, use and put away.
Fri Nov 10 2017 12:14pm |
Fri Nov 10 2017 12:41pm |
Once Again Thanks Col
Fri Nov 10 2017 12:43pm |
