Home > Faults & Fixes > Veru Strange Noise. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8826 |
A squeak or a constant noise like a whistle?
Thu Nov 09 2017 1:38pm |
crdixon2004 Member Since: 09 Nov 2017 Location: Darlington Posts: 12 |
Hi. Yes when the gauge is at temperature the noise when accelerating starts all the wag through acceleration. Its the sound of like at alternator belt when cars are started on a morning and its slipping. But i know its not that because its only when i accelerate and then it only starts above 50. Once started it happens all the time until i slow right down around town then only on hard acceleration it starts again.
Thu Nov 09 2017 2:06pm |
Also there are no faults. I have had it into a garage and i firstly expected a hose but they cant see anything and just suspected the turbo straight away. But i prefer a different option before having to go down that route. |
Thu Nov 09 2017 2:11pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
You say at over 50mph does it seem to be engine or drive related ? Reason I ask is I had similar noticed it on hills like Sutton bank then I changed the torque converter earlier this year and haven't heard the noise since 2008 G4 RRSport TDV8 current
Thu Nov 09 2017 2:28pm |
Only when i accelerate on the drivers side. When i am not accelerating there is no noise at all. |
Thu Nov 09 2017 2:37pm |
The TDV8's are known for warping the exhaust manifolds and snapping the studs could be that as the exhaust expands when warm 2008 G4 RRSport TDV8 current
Thu Nov 09 2017 2:44pm |
Ah great so manifold replacement? Or amd new exhaust sytem. Lol ?? |
Thu Nov 09 2017 2:51pm |
Thu Nov 09 2017 3:37pm |
As I understand it it's a body off job though this is only what I've read on here . Try looking it up by the search icon 2008 G4 RRSport TDV8 current
Thu Nov 09 2017 3:43pm |
IT was always at the back of my mind was a turbo going to let go but 2 years and 20000 miles later as I say seemed to go after I changed the torque converter maybe just a coincidence did have the exhaust off might be worth checking the flange bolts as the fasten directly onto the turbo could be blowing on the offside 2008 G4 RRSport TDV8 current
Thu Nov 09 2017 4:20pm |
Ok mate thanks.
Thu Nov 09 2017 5:43pm |
Also i have notoced the coolant disappearing so topped it up and then i will see. Hope it is the water pump and nothing serious.
Thu Nov 09 2017 6:37pm |
The exhaust manifolds are body off and they are also about £600 each. Annoyingly, the manifolds on the FFRR can't be used but they are a fraction of the price. 2012 SDV6 - it's missing a couple of cylinders
Thu Nov 09 2017 8:45pm |
Water pump chsnge an easy job? |
Fri Nov 10 2017 8:24am |
