Home > Faults & Fixes > Electric windows do not work anymore at front left and right
rhenus132
Germany 2006 Range Rover Sport TDV6 HSE Lux Stornoway Grey
Hi All,
since some time, i don't know exactly my two front window doesn't working. The two back windows operating normal.
I have checked both connectors at the door (left and right) and also the fuses are ok.
Strange for me that left and right not working at the same time. When i press the switch for up/down there is also no noise from the door, so i guess there is no power /command to the lift motor.
I have checked faults with IIDTool but no error message.
I know there is a ECU under the seat connected to the switches from the door right?
Anything i can check, measure, reset?
To check the circuit i need electrical wiring diagram, but i can't find this on the web...
Thanks in advance for any help.
Frank
Post #464490 Sat Jun 13 2015 8:41pm
rhenus132
No idea?
i still can't open my front windows on left and right side Shocked Big Cry Rolling with laughter
Post #464559 Sun Jun 14 2015 9:02pm
Bodsy
Site Sponsor
Disconnect the battery cables, then connect the cables to each other (OFF the battery) for 20 seconds.
Reconnect and see if it makes a difference. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #464571 Sun Jun 14 2015 10:05pm
rhenus132
i have read in other forums to short both cables for 10 minutes... i did that and no change...
what about the ignition?
have to be around 20 seconds?
what next step? any relation to this box under the passenger seat?
Post #464581 Mon Jun 15 2015 5:58am
Bodsy
Site Sponsor
Hold the window close button up and keep it closed for 20 seconds, may just need resetting home position. Bodsys Brake Bible
See it HERE
Post #464587 Mon Jun 15 2015 7:43am
rhenus132
on both sides? i have problems on both sides
for passenger window on passenger side or at the 4-switch from drive side?
thanks
Post #464588 Mon Jun 15 2015 7:45am
rhenus132
i am still struggling with that problem...
is it right that the switches at the 4 doors connected to that ECU under the passenger seat?
is there any interlocking to open the windows?
is there any fuse beside that fuse for the window itself?
any idea what to check?
Post #464817 Tue Jun 16 2015 6:36pm
rhenus132
I just found out, that also the rear window can't be open...just the hatchback...
to both front window and rear window.... Shocked Rolling Eyes
what could be the reason, any common part? Rolling with laughter Bow down
Post #465358 Mon Jun 22 2015 11:47am
rhenus132
Solved!!!!
Problems is solved...
Post #465625 Wed Jun 24 2015 8:32pm
tanloverluke
great news...how did you solve it ? Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #465630 Wed Jun 24 2015 8:53pm
rhenus132
I found the electric drawings
Than i opened both door covers and checked voltage on both motors...
When i pressed the switches for up and down the function was ok...
than i saw on the second page there is a contact B coming to both front window motors
When i disconnect this from motor windows not working. When i put that contacts C0740-6 and C0741-6 to ground it was working. But now i can open close without ignition on... i think that signal is a permission.
Permission ok 0V = Ground
Permission no = 12V
But in my case there was always 12 V so i have to make it 0 by contacting to the ground...
Now the question, how to solve this to get original back?
Post #465631 Wed Jun 24 2015 9:03pm
jsrr
2006 Range Rover Sport TDV6 HSE Java Black
Hi.
Found this on rangerovers.net
http://www.rangerovers.net/forum/9-range-r...-down.html
Post #466367 Thu Jul 02 2015 8:49pm
Smartie
Germany 2007 Range Rover Sport Supercharged Java Black
Hi Rhenus 132,
I had the same problem with my 2007 RRS windows. I tried your solution and it also worked for me.
Did you manage to find the real problem and resolve it, or have you stayed with your temporary solution. I would be interested to know if you found the real cause....
Regards
Smartie Very Happy
Post #540323 Tue Nov 07 2017 12:17pm
