Home > General > Black smoke
Josb1990
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Java Black
Black smoke
Hi I have a range rover 4.4 v8 which has started puffing out clouds off black smoke does anyone know what the problem could be thank you
Post #539969 Thu Nov 02 2017 12:02pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
If you're losing power in low gears it's probably the same as mine... split turbo hose. Others on here will give useful responses. Barrie.
2005 RRS 2.7TDV6 from 2017 -2024. Best car I ever had.
Current: 2018 Ford Ranger Wildtrak 3.2
Post #539970 Thu Nov 02 2017 12:56pm
BKHK
Australia
Split turbo hose? Not in a 4.4 bent 8 Rolling Eyes
Post #539974 Thu Nov 02 2017 1:25pm
Black smoke suggests the engine is running rich. You need someone to check for error codes to see where to start with it. Could be an injector issue, MAF issue etc. Might be worth checking/changing the air filter just in case it's heavily contaminated and thus partially blocked. 2012 SDV6 - it's missing a couple of cylinders
Post #539975 Thu Nov 02 2017 1:36pm
BJH1959
I will leave it to those who know more about these things than me. Rolling Eyes Bow down Barrie.
Post #539978 Thu Nov 02 2017 2:01pm
Tim in Scotland
It can only be the 4.4 Petrol as his avatar shows a 2005 V8, 4.4 Sdv8 only came on line in 2013/14. I don’t think the 4.4 V8 has any turbos, it is a naturally aspirated Petrol 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #539987 Thu Nov 02 2017 2:43pm
BJH1959
Thanks Tim. Now I know. Thumbs Up Barrie.
Post #539993 Thu Nov 02 2017 2:50pm
Josb1990
Sorry it's a vouge 2003
Post #539995 Thu Nov 02 2017 2:53pm
The 4.4 V8 petrol is a rare thing in the RRS. You might have more luck in the Range Rover forum: http://www.fullfatrr.com/forum/ as there are more likely to be more of them with knowledge of the engine.
Basic principles apply, however, so checking the obvious stuff (codes, filters etc.) would be a good start. 2012 SDV6 - it's missing a couple of cylinders
Post #540001 Thu Nov 02 2017 3:04pm
Tim in Scotland
Then it will be a Vogue L322 Range Rover as Sports only started production in 2005. The V8 petrol in the FFRR is a BMW unit at that stage of production so also BMW forums will be able to help. Good luck with getting it sorted, as mentioned FullFatRR forum is a great place to start. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #540003 Thu Nov 02 2017 3:13pm
