Home > Technical > Fault coder reader fails to connect to any modules
Ste815l
Try to read fault codes on my rrs and it sees the modules but fails to connect to them just says error. My rrs is running fine with no problems just carnt understand why no connection this has been tried on a 2k snap on diagnostic. And land rover specialist diagnostic both come up the same error connecting any ideas. 2006 rrs
Post #539893 Wed Nov 01 2017 4:11pm
Ste815l
Guess ppl don't have a clue like me haha
Post #540000 Thu Nov 02 2017 4:00pm
Scrumpy
My only guess (and it is a guess) is maybe a problem with the OBD connector?
If the car is running fine but you can't find any modules then suggests a connection issue with the diagnostic connection?
Would be interested to see what you eventually find out!
Good luck 2016 RRS SVR Estoril Blue
Post #540006 Thu Nov 02 2017 4:33pm
Nige
United Kingdom 2006 Range Rover Sport TDV6 SE Java Black
we had this today,,and would not connect,,mine is an 06 sport ,but had to use the( range rover all models ) selection rather than (range rover sport) selection,,connected straight away BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
two discos v6 off contract (for sale) before they go to scrap
Post #540011 Thu Nov 02 2017 5:37pm
Ste815l
I'm just thinking maybe it has had some kind of obd deterrant fitted to stop car from getting keys cloned ect. Just a thought.
Post #540013 Thu Nov 02 2017 5:58pm
Nige
the one i had hooked up was a delphi linked to an i pad,,it would not connect at all till ,just keot saying VIC not connected ,we went into the menu of different land rover models,,just abut to give up and just selected the range rover all models,, BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Post #540020 Thu Nov 02 2017 7:24pm
Nige
just a question ,,as i was only borrowing this Delphi DS150E anyone know if this reader could programme (code )the fuel pump and injectors to my existing ecu??? its a complete engine out of another sport BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Post #540021 Thu Nov 02 2017 7:28pm
