Home > General (L494) > Flat battery(?) |
Here is your solution http://www.rrsport.co.uk/forum/topic49141.html
Mon Oct 30 2017 9:32pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1725 |
12 volts is getting on the low side?
Mon Oct 30 2017 9:39pm |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
I have a dashcam but I have been using it for 4.5 years in this and previous cars with a power saver and never had any problems because of it. I will explore the solar charger but can’t get my head around what fast tracked this drain. Or was it not really a battery drain but battery management screwup? Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond |
Mon Oct 30 2017 9:48pm |
Thanks but I have been using it on the 12v setting for a long time. In fact, I was using it at 11.8v in my Black Edition as I wanted it to keep recording for longer. Never had a problem and I didn’t even have a CTEK at that time! The dashcam shuts down at 12v/11.8v but even after that there has always been sufficient power to start the car, open the doors/tailgate etc. and never saw that particular low battery warning. According to this chart, 12v is 50% which should still be enough to start the car. The only thing that was different this time was that I actually remembered to enable Valet Mode before leaving the car but I’m sure that’s completely irrelevant. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond |
Mon Oct 30 2017 9:58pm |
From your comment from the AA person, couldn't it just have been a problem with the lead over time getting to a point where it needed sorting as had come to that "loose" point where problems occur? Or just needed a reset, as these cars have loads of inherent one off type issues which can return but the reason never being found out. Like disconnecting your battery and waiting, or shorting leads together, then this action clears the fault.
Mon Oct 30 2017 10:18pm |
You’re probably right Johnski. I am just not sure whether there really was a loose/dirty connection or the AA guy just said so because it has been a problem in other cases. I guess if it doesn’t reoccur after I disconnect the CTEK, I can put it down to the connection or monitor reset (or both) and move on. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Mon Oct 30 2017 10:34pm |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
Without any doubt your"always on" dashcam is the issue. I have seen this many times.
Tue Oct 31 2017 8:02am |
OK. I will increase the voltage on it and see how it behaves. Just seems strange I never had any issues in the last 4 and a half years, including the time when it was set to 11.8v. Like I said, I have left the car unused for much longer periods than 4 days and in colder weather too. Most working weeks, the car isn't used for 4-5 days until the weekend so should be easy for me to try leaving it without charging at current and higher voltage settings and see what the difference is (if any). Thanks all for the comments/suggestions Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Tue Oct 31 2017 9:37am |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5584 |
I've had dashcams set to lowest voltage using parking mode on RRS, DS, Mitsubishi phev and Lexus - I've also fitted them in my kids punto and never had flat battery issues
Tue Oct 31 2017 10:38am |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1133 |
Tue Oct 31 2017 11:54am |
Update: I left the car without charging for 3 and a half days. During this period it only did one very short trip to the supermarket one evening. So a journey that would have drained it more than would have charged it. No low battery warning and the dashcam is still on at the same setting as before i.e. voltage hasn’t dropped below 12v during this time. I am not so sure now it was the dash cam that drained the battery flat in 4 days while we were away. It hasn’t done anything nearly as drastic as that in the last few days (consistent with my experience of this dash cam and battery saver for few years). Don’t know what the reason was last time. Will monitor it for even more days next week before I change voltage setting up. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Fri Nov 03 2017 10:05pm |
My money is on something in the vehicle system not shutting down when you left Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Fri Nov 03 2017 10:52pm |
