Home > Technical > Sorry..... Jacking up question...
Jampot1979
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
Hi, I need to remove the front passenger wheel as I want to clean up/paint the brembos caliper as it looks horrible.
Anyway, I am completely confused after reading many posts on here on what is the correct procedure etc.
I know the standard scissor jack is not the best. I do have some heavy duty axle stands to assist.
Am I right in saying that I have to set suspension to off-road height, and leave the tailgate hatch open?
Post #539232 Thu Oct 26 2017 7:29am
Socast
I've no idea why folk have decided that it needs to be complicated to jack these cars up as it's not, if you read the manual there is nothing in there that says anything about changing the vehicles height or leaving doors or the boot open.
Leaving a door open stops the vehicle from trying to auto level itself (Not sure if this is a global thing, but my vehicle still levels itself with the boot open), so there is a small chance that if your jack isn't seated correctly, that the vehicle trying to level itself could make the jack slip. That being said, if you've seated the jack properly in the first place then that's not an issue.
I personally put the vehicle into off-road height (simply to allow more room under the vehicle to place the jack), apply the park brake, jack the vehicle up, place the axle stand/s and then get on with whatever I need to do.
Post #539235 Thu Oct 26 2017 7:50am
Tim in Scotland
And don’t forget to put the wedge in place on the diagonally opposite wheel! I agree a lot of guff has been posted about opening doors and tailgate and last time I had my car in a tyre Bay I asked the fitter why he opened the tailgate and he gave the usual story about self levelling so I showed him it made no difference and that it isn’t mentioned in the manual. With regards to opening the passenger/ driver doors the only reason I could see for opening them is that some trolley jacks when being pumped up can come very close to the door skins and could either give the operator some bruised knuckles of the owner some dents in the door panels and I agreed with my guy that leaving the doors nearest the jack open was probably a good idea to prevent the possibility of damage to the doors.
There are , however, issues over the safety of the supplied jack - it really isn’t up to supporting the weight of the car and can slip on some surfaces, I got round that when I had L320 RRS’s by carrying a sheet of 2mm plywood as a base for the jack, the weight of the car on the jack forced the ply to distort and grip better on the ground surface. I wouldn’t recommend leaving the car on that jack any longer than is necessary to change a wheel after a puncture, axle stands or a proper trolly jack are much safer for any longer. 2018 Melting Silver Mini Countryman PHEV - a test car before Seeing if I could go to totally Petrol/Diesel free motoring
Post #539238 Thu Oct 26 2017 8:25am
Danv8
United Kingdom 2008 Range Rover Sport TDV6 HSE Lux Alaska White
I always thought it was the opposite, lower the suspension then lock in in place before jacking up. I got told this by the service guy at Land Rover as it can prevent damage to the air bags.
Don't shoot the messenger its just what i got told.
Post #539239 Thu Oct 26 2017 8:41am
Socast
The door preventing the vehicle from raising/lowering or trying to self level is a safety feature, it prevents anything or anyone from getting trapped/pinned either above or below the door, it also prevents accidental damage.
Post #539242 Thu Oct 26 2017 8:47am
Simple really. Trolley or bottle jack on the jacking points as indicated in the manual. Axle stand immediately adjacent the jacking point. Job done. Opening a door will prevent suspension movement - try selecting a height change with the doors anything other than fully shut and you'll see. Can't say I've had a problem with suspension movement when lifted anyway.
Use the LR jack only as an emergency road side tool. It's not a workshop tool!
You can apparently jack under the lower suspension arm where it meets the upright but I've never tried it. This avoids having to lift the body through the full suspension movement. 2012 SDV6 - it's missing a couple of cylinders
Post #539371 Thu Oct 26 2017 7:05pm
Tyrefitter
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
I usually jack under suspension arms & ive never altered suspension settings & never had a suspension issue.
Andy Andy.
2014 RRS SC santorino,coris roof.
2014 Evoque D-Lux Fuji
Previous motor.
2016 VW Amarok Highline,candy white
2014 RRS AB FUJI
2012 RRS Dynamic red edition Fuji
2012 RRS SE santorino
2015 Navara White
2008 RRS white TDV8
2007 RRS black TDV8
2002 RR Vogue
1996 P38 2.5 HSE.
Post #539376 Thu Oct 26 2017 7:16pm
Johnski
If you have your hazards on and drivers door closed you can alter suspension with fob, or terrain control rise/ fall, with ignition either on or off, but none of other three doors effect the suspension on 2011-2013 models according to the users handbook.
It seems the critical thing is “hazard warning lights” on, which are normally on, when changing wheel for puncture at roadside or broken down. . John
Post #539381 Thu Oct 26 2017 7:27pm
MartinsTDV8
Scotland 2007 Range Rover Sport TDV8 HSE Buckingham Blue
I’m pretty sure you have to raise it up, open a side door, then take off one of your shoes and a sock, let one of your testicles hang out. Then I belive it is safe to remove the wheel. Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Previously owned 1999 Disco 2 TD5
Disco 3 HSE TDV6 2007
Post #539387 Thu Oct 26 2017 8:26pm
sweetafton
England 2011 Range Rover Sport Supercharged Santorini Black
Hey Martin think it’s both testicles out mate. Ha ha. Best one I’ve seen in a long time. Thumbs Up Bow down Rolling with laughter MY11 Autobiography supercharged. Santorini Black. Monaco interior. Rear screens. Privacy.
Gone MY08 Supercharged HST. Java black. Ivory premium interior. Rear screens. Privacy. Missed a lot.
Gone MY04 Discovery V8 Petrol ES Premium. Awesome.
Post #539389 Thu Oct 26 2017 8:50pm
Nah, testicles out only applies to the 5.0SC. The diesels just require a trouser leg to be rolled up.
There's a TSB about it somewhere...
Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #539391 Thu Oct 26 2017 8:53pm
Cymruambyth
Wales
Shocked Shocked Laughing Steve.
Post #539392 Thu Oct 26 2017 8:55pm
garrycol
Australia
Locking the suspension at access height stops the system from pumping up but there is nothing in the system that stops the wheels coming down under gravity when the car is jacked up.
The car has to be lifted up a far way to get the wheel off the ground when using the standard jacking points and this takes a lot of effort with a hand jack - so why not let the car do most of the work and raise it up as much as possible to minimise the manual effort when doing the final jack off the ground.
Opening doors an boots etc stops the vehicle height being changed - it does not stop the vehicle adjusting its level - even if it does on a jack - is not really an issue as it is only a few mm.
So if using the standard jack positions - raise the car to max (chock wheels) and jack and then put stands under for safety. Alternatively use a suitable jack under the suspension arms and jack then put stands - as you are lifting the wheel directly there is no need to raise the vehicle first as the jack is lifting the wheel directly and noy through the suspension.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #539399 Fri Oct 27 2017 3:52am
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
