Home > In Car Electronics > Clock on dash disappeared
Tom55
Had a few updates by bodsy a few months ago, one of which was the clock added in the dash. Cars been in a local garage for a few weeks having some issues rectified, got it back now the clock has vanished, replaced with . . : . .
Is there anything i can do to set the time again or do i need bodsy to plug his machine in again? Have set the clock in the sterio up and has not made any difference.
Post #538809 Fri Oct 20 2017 6:06pm
Scrumpy
Not sure if it will work and I am no expert but I have just bought a IID BT tool to add clock to dash and noticed that it only sets at 00:00 so maybe worth disconnecting the battery tonight just before midnight for a few minutes and reconnecting it to see if the clock sets the time.
It sounds like it is still there, just not set.
Would be interested to hear the solution.
Good luck --------------------------------------------------------------------------------------------------------
Post #538810 Fri Oct 20 2017 7:08pm
Scrumpy
I just found this on the Gap Diagnostic IID tool manual. Seems like it might need a reset with the tool;
4.7.11 All ECUs
Vehicle Reset (L322-10, L319, L320)
This routine will send a reset or reboot command to all ECU’s. It is equivalent to a soft reset.
Usage
On L319-04, it should be used to restore the clock on the instrument pack ECU (--:-- displayed). It can
also be used to solve other unusual issues.
Note : This function will return all user settings (radio station etc) to factory default.
So maybe if you don't have the tool, disconnecting the battery might work as a soft reset.
Good luck! --------------------------------------------------------------------------------------------------------
Post #538825 Fri Oct 20 2017 10:13pm
Tom55
I’ll give it a try tomorrow, thanks very much for the info mate Thumbs Up
Post #538827 Fri Oct 20 2017 10:24pm
geoffsnook
When you set the clock on the radio it also sets the clock on the dash Thumbs Up
Post #538856 Sat Oct 21 2017 1:45pm
Wayneclarke
had the same problem after i had the clock done by Bodsy it disappeared due to me false starting the car, all i had to do was reset the ecu
Post #538903 Sun Oct 22 2017 2:37pm
Nicard
had the same fault, reset the ecu and this solve it for me.
Post #538919 Sun Oct 22 2017 6:56pm
Bodsy
Site Sponsor
It can happen when the battery is low. The ecu gets drained of power and they start up in the ‘wrong’ order. The instrument pack syncs to the radio for the time and it misses that signal order.
Charge the battery up and then remove the battery terminals from the battery and hold them together for 10-20 seconds.
Once reconnected, reset the time and away you go.
It’s always due to low battery. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #539048 Tue Oct 24 2017 8:31am
Tom55
Thanks all sorted now Thumbs Up
Post #540396 Thu Nov 09 2017 8:05am
RobP
Is it possible to set the clock time with IID tool ?
Clock is displayed but wrong time as have an aftermarket radio, I know I could do a midnight reset but now have an IID tool and wondered if I could sort with it? TDV8 now with extra grin factor thanks to Alive Tunning
Post #551643 Fri Mar 16 2018 10:39pm
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
