Home > Technical > Test fuel burn heater? |
NeilRRS Member Since: 18 Aug 2016 Location: Stone, Staffs. Posts: 36 |
Is there a way to test the fuel burn heater on a 2010 model?
Thu Oct 19 2017 9:59pm |
Can be primed with fuel and test fired using IId tool regardless of outside temp to test 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Thu Oct 19 2017 11:01pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
l The FBH can be put in a test mode with some code testers. My local Indie did this for me recently (for nomcharge) as my remote control stopped working. But then they did install the remote. I believe that the test then ignores the parameters that might prevent it starting (low fuel, too high ambient temp etc.) and confirms if the heater is ok. I guess this would also work for the timed heater option. In my case they confirmed heater was ok and also that the remote unit in the car was fine. It just needed disconnecting from power, a 30 second wait, and then reconnecting to get it working properly again. (They did complain about the clouds of black smoke that enveloped their garage when they did get it going. It seems that the heater was being primed but not firing up and so a significant quantity of fuel needed to be expunged)😊 Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Thu Oct 19 2017 11:09pm |
Do you know the proceedure for this as I now have an IID tool. The method I tried just said to start the engine of the car and then I just heard the fan kick in. Didn’t know if I have to prime it first etc. Would be better to test with engine off too. |
Fri Oct 20 2017 7:55am |
I'm sure Buckster will have the definitive answer but I don't recall my Indie starting the engine, they may (or may not) have switched the ignition on but that's all. It took about 10 minutes to complete the test Robin
Fri Oct 20 2017 8:14am |
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 |
Will it not come on when using the remote if outside temp is above the set value as I tried mine the other day and it wouldn't come on.
Using the GAP Diagnostic IID BT tool, you can check and operate at any temperature.
Fri Oct 20 2017 2:38pm |
Mine all works fine. Took the battery out of the remote to see what it was so I can get a replacement and then it worked fine.
Fri Oct 20 2017 8:34pm |
Hi NeilRRS,
Fri Oct 20 2017 10:03pm |
Whilst I don’t have a timed heater, I do have (as mentioned above) a remote control. I’ve used it often during the summer and it overrides the temperature restriction along the lines of riverblanche’s comment re the timed option.
Fri Oct 20 2017 11:26pm |
Only 2 miles? just run or even walk to the Gym instead, you will get fitter faster, no bad green inpact on planet earth, as you don't waste fuel and cause high emissions through running car when cold and using FBH, which doesn't go through Cat system etc. John
Fri Oct 20 2017 11:50pm |
Haha. Good point John. By the time I get to the gym I'll be too knackered to do anything - so it'd save me gym membership as well. Robin
Sat Oct 21 2017 12:13pm |
Hi, I was with you Eaters, spot on, right up to the
Though you must be going for the Sauna to sooth a bad back or something you could use some of your spare wheels instead of weights as well as for the FBH consumption ISTR 0.4L/hour on full chat and 0.2L/hour when it steadies down, well worth it Porsche Cayenne 2022 gone Porsche Cayenne 2020 gone Corris Grey HSE Dynamic 2016 gone Ipanema HSE lux 2010 gone Rimini HSE 2005 !! |
Sat Oct 21 2017 7:52pm |
Oh I get it. Have a go at Eaters time
Sat Oct 21 2017 11:25pm |
