Home > Maintenance & Modifications > Sump Guard Removal |
I feel your pain; having recently struggled with one of the bolts on my undertray.
Fri Oct 20 2017 1:22pm |
GARYF123 Member Since: 03 Jan 2015 Location: leeds Posts: 143 |
Hi, I had same problem last week! I ended up using a angle grinder with thin metal cutting disc and cut slot into bolt head. I cut full depth which allowed me to knock the bolt round. I could also reuse the butchered bolts to temporarily hold the tray until I purchase replacements. I don't think you will damage the welded captive nuts as I was using a impact wrench, hammering and grinding and they didn't budge!
Sat Oct 21 2017 1:23pm |
slinger Member Since: 11 Sep 2016 Location: Loughborough, Leicestershire Posts: 19 |
Thanks for the replies guys. Seems this is yet another design feature from Land Rover. I managed to get the last three bolts out with an air chisel and using a hammer and chisel. Replacement Land Rover bolts all round would have been over £30 but I got a full set of flanged bolts and bought nuts, springs and washers for all for only £3. I didn't need nuts on all but with not knowing what I would end up with and for the cost I didn't want to half do the job. Copious amounts of copper grease and it is all back together after changing the oil.
Sat Oct 21 2017 4:08pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8800 |
It makes one wonder how careful the servicing has been if the bolts were so badly seized / corroded. Taking the sump plates off would be part of an oil change... 2012 SDV6 - it's missing a couple of cylinders
Sun Oct 22 2017 7:19am |
WesleyThompson Member Since: 01 Apr 2018 Location: Cheshunt Posts: 2 |
Same happened to me today I had to call it a day and leave the car on the ramps. Left the bolts with penetrating fluid on to soak through the night |
Tue Apr 03 2018 8:00pm |
Morgi27 Member Since: 31 Jan 2015 Location: Birmingham Posts: 88 |
If it's supposed to have had oil change 10 months ago carnt see how they would have rusted fast!
Wed Apr 04 2018 11:24am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4817 |
Dealers don't always drain the oil these day's via the sump plug, they use a oil extraction pump to remove the oil from the engine using the built in tube, although I don't know if a 58 plate vehicle has this facility, which could explain why the guard is not always removed.
Wed Apr 04 2018 11:42am |
