Home > Technical > More tails of locking wheel nuts. |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 |
Well after heeding the advice given on here about ditching the locking wheel nuts due to the common problem of them separating, which just causes the top part of the nut to spin freely when you try and remove them, I thought I better change them. Well I ordered a new set of wheel nuts and the other weekend decided to swap them over. All went well until I tried to remove the last one, unfortunately I was too late as it had already failed. I had a good read of various forum threads and at the end of it I was fairly confident I would be able to remove it. One of the best threads was on the Disco3 forum http://www.disco3.co.uk/forum/topic68161-45.html
Sat Oct 14 2017 1:38pm |
That's a good point and I actually over torques the remaining nuts on my wheel to see if would help, but obviously in my case it didn't. I also spoke with a friend who works in a Land rover garage to see what they do, He said they sometimes get lucky if they remove all the other wheel nuts and go for a gentle drive, they have a roundabout close by and do a couple of circuits of this and come back, he said that if they made sure the top and bottom parts of the wheel nut were aligned and as long as the lugs/ cut outs on the bottom part weren't rounded off they could often remove them this way. |
Sat Oct 14 2017 2:19pm |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 |
"remove all the other wheel nuts" I don't believe that for one minute, they may loosen them, but they will never remove them, that's just crazy 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater ))) |
Mon Oct 16 2017 1:16pm |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
Steve. |
Mon Oct 16 2017 1:29pm |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
mine did the same, rather than spending hours cursing,These guys also do excellent bits of kit for removing any wheel nuts, and if you bob over to Castleford, they will remove then in minutes. for around £15
Tue Oct 17 2017 8:38pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
Also ditch the nuts with covers for ones without.
Tue Oct 17 2017 9:12pm |
