Home > Maintenance & Modifications > Removing undertray |
GARYF123 Member Since: 03 Jan 2015 Location: leeds Posts: 143 |
Sun Oct 15 2017 12:18pm |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
First I'd wash off that WD40 and use a proper penetrating oil, like Plus Gas or the like. WD40 does absolutely nothing for seized bolts, it must be one of the most incorrectly used products out there. 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
Sun Oct 15 2017 3:13pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4753 |
WD40 does help on a RRS (whether designed to or not)
Sun Oct 15 2017 5:02pm |
Well this is topical.
Sun Oct 15 2017 6:06pm |
MartinsTDV8 Member Since: 22 Feb 2017 Location: County of Sutherland. Posts: 140 |
Gary
Sun Oct 15 2017 6:49pm |
LTFR Member Since: 10 Oct 2017 Location: Liverpool Posts: 3 |
Got to agree with Paddi on that one, those IRWIN bolt grips have been worth their weight in gold and have helped me out more times than i can remember ! 13MY HSE BLACK SDV6 in Siberian Silver |
Sun Oct 15 2017 6:52pm |
They all have 13mm heads and are M10 with 1.5 pitch threads. The threaded part of the bolts is 22mm. Two of the bolts have nuts and all the others locate into captive nuts. The bolts are not just standard bolts though - they all have a flare below the head and a captive washer with locking serrations. Your best bet is to ring Dan at Duckworth parts with your VIN to hand and he should be able to order you a complete set. Duckworth are site sponsors so you get a small discount. 2008 MY Java Black TDV8 HSE |
Sun Oct 15 2017 7:26pm |
Didn't know they were captive |
Sun Oct 15 2017 7:29pm |
Thanks Gary, its never easy Previously owned 1999 Disco 2 TD5
Sun Oct 15 2017 7:45pm |
Well they can't be removed from the bolt. Bu*****d if I know how they get them on in the first place. Maybe the washers are put on before the threads are rolled? 2008 MY Java Black TDV8 HSE
Sun Oct 15 2017 7:50pm |
Thanks all for replies.
Sun Oct 15 2017 11:09pm |
I believe the small one is the most difficult |
Mon Oct 16 2017 6:02am |
