Home > Faults & Fixes > Transfer box replacement
R1CHD
United Kingdom 2005 Range Rover Sport TDV6 SE Java Black
Good evening,
Has anyone replaced a transfer box on a Sport? Mine is a 2005 2.7 TDV6 RRS, I have a rasping noise on light throttle/coasting like a tin of ball bearings being shaken I think it’s the transfer box at fault but I just need some info on replacing the transfer box is it straight forward? Step by step guide would be great! I’m a mechanic by trade so have access to a ramp tools etc just need some guidance before I start
Thanks
Post #538028 Tue Oct 10 2017 9:12pm
Stevepd
R1CHD,
do you do your own servicing and stamp the book?.
Steve.
Post #538047 Wed Oct 11 2017 8:26am
R1CHD
Hi Steve,
No sorry Steve I don’t have a stamp that I can stamp the book I’m a Service Manager for a HGV company so have access to the facilities
Thanks
Post #538048 Wed Oct 11 2017 8:44am
GodivaNige
Do an oil change first, it will tell you if the problem lies with the transfer box. Your issue could be something else, possibly the torque converter. Little point in shelling out for a new transfer case when a relatively cheap inspection of the oil may rule out a fault.
Post #538049 Wed Oct 11 2017 8:51am
R1CHD
Hi Nige,
Yeah I have replaced the oil and the fault appears the same, the old oil was dirty but no signs of metal, this problem seems to be common on 2005 RRS with some people reporting no fix after replacing all sorts of components but also no component failures due to the noise over thousands of miles so I’m a little stuck as to where to go to be honest the noise is just more annoying than anything else and I’m sure most people wouldn’t notice it but I guess it’s the mechanic in me!
Post #538057 Wed Oct 11 2017 10:01am
Stevepd
R1CHD wrote:
Hi Steve,
Thanks
Sorry didn't mean that to sound like a loaded question (re-reading it it sound just that!).
Steve.
Post #538060 Wed Oct 11 2017 10:29am
SRE
Spain
Does it make the same noise in both High and Low range ? In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #538062 Wed Oct 11 2017 10:47am
GodivaNige
R1CHD wrote:
Hi Nige,
Hi, a lack of metal in the oil is a good sign. Ive also seen reports on the internet about this light throttle resonance and some saying they cured it with a new torque converter. When it is happening, does it the noise disappear instantly with slight increase in throttle? There is a thread somewhere within rrsport of a similar complaint and a dealer reported it as a characteristic of the gearbox/torque converter, the noise occurring at the point when the torque converter lock up is not quite engaged.
Post #538063 Wed Oct 11 2017 11:07am
R1CHD
Hi
it's only really noticeable when you are driving along and feather the throttle and with the window down , I can't get it to do it and idle or replicate it stationary, it does clear instantly when I increase or let off the throttle or with a gear change, initially I thought it was a broken bracket vibrating some where but I cant find anything, I have replaced the propshaft center bearing, alternator belt tensioner, idler and belt, carried out a full engine service and replaced the front diff and transfer box oil, I need to carry out a rear diff oil change but cant for the life of me find the fill bung, oh and I might do a gearbox oil and filter change just to tick it off the list but nothing has worked so far
Post #538070 Wed Oct 11 2017 12:09pm
Paddi
Here's the guide you were looking for:
https://www.disco3.co.uk/forum/topic47890.html
Not had to do that myself thank goodness. But I have changed the rear diff oil a couple of times. IIRC the drain plug is on the bottom and the fill plug is on the rear face of the diff casing? Do you have an electronic locking diff? Maybe they are different 2008 MY Java Black TDV8 HSE
Post #538074 Wed Oct 11 2017 12:49pm
Disco_Mikey
It's a gearbox related noise
Sometimes cured by a new TC, others no such luck...
Post #538075 Wed Oct 11 2017 1:03pm
GodivaNige
Maybe a gearbox flush first then, not that its a guaranteed cure but worth a go.
Post #538077 Wed Oct 11 2017 1:22pm
R1CHD
Thanks for the info I wonder if its worth contacting Land Rover to see if there are any software updates available for the gearbox or engine that could help with this or I have heard that an independent ecu remap has cured similar faults but I have no proof of this, does anyone have an idea on the cost of replacing a torque converter?
Thanks
Post #538078 Wed Oct 11 2017 1:32pm
Bodsy
Site Sponsor
About £1200ish
A flush can help, but won't always eradicate the noise.
The noise also will come back in the future as it's a trait of the TC wearing.
If you don't get rev fluctuations then I wouldn't bother replacing the TC just yet. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #538109 Wed Oct 11 2017 6:42pm
R1CHD
Thanks for the info I think I’ll just let it lie for now
Post #538171 Thu Oct 12 2017 9:11pm
