Home > In Car Electronics > Retrofit phone module
HughN
Wales
Greetings,
I've searched the forum but not found exactly the answer I'm looking for so here goes...
I have an '06 TDV6 without any 'phone connection (it says phone not installed ' (or similar) if I try to use any controls). I'd usually fit a parrot kit as I have to previous cars but the Harmon Kandon system seems to make this complicated and expensive. Having gone down this route on previous LRs it usually ends up with a massive 'crash' when an audio relay switches.
If possible, I'd like to avoid any of the modules that use the Aux connector or FM transmitters.
To get Bluetooth connectivity, is it just a case of retrofitting a 'phone control module' and, if so, do the various manufacturers (Nokia, Motorola, etc.,) mean they only connect with 'phones of those brands, or are they essentially same?
My use of a 'phone is typically rare and little more than "Let me pull over and I'll ring you back" but it needs to be with the minimum of distracting faff.
Any thoughts or suggestions gratefully received.
Thanks,
Hugh
Post #536901 Mon Oct 02 2017 7:35am
geoffsnook
Site sponsors on here sell complete retrofit gets easy to fit and around £300 i seem to recall Thumbs Up
Post #536902 Mon Oct 02 2017 7:43am
geoffsnook
Sorry these guys dont appear on here under sponsors so take a look on disco3 for bodsey geoff. flack wiggs etc thet have the knowledge and more than likely the parts on the shelf Thumbs Up
Post #536904 Mon Oct 02 2017 7:50am
HughN
Wales
Will-do. Thanks. Thumbs Up
Post #536905 Mon Oct 02 2017 7:52am
It is possible to fit a parrot or similar.
The headunit has a mute and audio input (on smaller connector)
Pin
10 Mute
3 Audio In +
5 Audio In -
Obviously the controls won't work with it though.
P.S My nokia kit, works with my iPhone 5 & 6
Post #536920 Mon Oct 02 2017 12:05pm
nebc100
Luxembourg 2008 Range Rover Sport TDV6 HSE Java Black
Are you sure your rrs doesn't already have the bluetooth installed?
Mine said "phone not installed" when i pressed any of the phone buttons before i had worked out how to connect my ohone via bluetooth.
Post #537673 Sat Oct 07 2017 9:03pm
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
HughN,
Which controls are you actually talking about exactly?
Do you have the two circled buttons on your steering wheel?
If so you have some sort of OEM Telephony System installed. Have you tried pairing your phone whist the Sport is running?
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #537704 Sun Oct 08 2017 9:00am
