Home > Technical > 5.0 misfire on 1 bank with no obvious cause
Page 3 of 4 <1234>
GodivaNige
If the cam timing is out, the engine will definately run rough.
Get it checked ASAP. You don’t want the chains to skip a tooth, to be honest, I’d stop using the car in the meantime. Whilst the replacement of the guides is not a cheap job, it’s considerably cheaper than a new engine.
Post #537417 Thu Oct 05 2017 2:23pm
tom0311
United Kingdom 2009 Range Rover Sport Supercharged Autobiography Santorini Black
Thanks, I'll give the garage a call about it now. Any experience on how much it costs for guides?
Post #537418 Thu Oct 05 2017 2:25pm
GodivaNige
Not sure about costs, there are a few snippets of info on the internet that a search will bring up for you with some stories of other owners that have had the work done.
Post #537420 Thu Oct 05 2017 2:34pm
tom0311
Thanks. I've contacted the garage, hopefully will get it in soon. Surprised it doesn't raise any faults.
Post #537440 Thu Oct 05 2017 4:03pm
My Jag sometimes sounds like a bag of nails on idle. (pinking).
I disconnect the air meter, turn the ignition on for 5 seconds. Turn it off. Reconnect air meter lead.
Once restarted it sounds perfect (as the fuel trim has been reset)
Post #537449 Thu Oct 05 2017 5:34pm
tom0311
Which engine has your Jag got Andy? Seems chain guides are a known issue on the 5.0 and can be f-series expensive to fix. Usually throws up faults though. Garage can't look at the car until late next week, so I'm stranded for now as I really don't want the engine to croak.
Post #537450 Thu Oct 05 2017 5:40pm
An old 4.0 Supercharged V8
Post #537455 Thu Oct 05 2017 5:57pm
Timing Chains, Google Land Rover LTB00474 should find some info.
NAS but should be same I would think, not very good copy I'm afraid. PM me an e-mail address and can send better copy if you want it.
Post #537494 Thu Oct 05 2017 10:24pm
tom0311
Nice one Col. Looks like this might be the issue after some more googling. Been an interesting 3 months of ownership so far. Hopefully once I get this nailed it'll behave. I'll chase the garage tomorrow and mention the TSB.
Thanks for the help!
Post #537497 Thu Oct 05 2017 10:42pm
Have a look at this, will give a insight to engine takes a couple of mins. to download.
http://www.jagrepair.com/images/Training%2...-15-09.pdf
Post #537498 Thu Oct 05 2017 11:30pm
tom0311
My VIN starts with 'SA' according to the IID tool so I suppose that TSB doesn't apply to me. Symptoms seem similar tho. Noise + misfires. Nothing back from garage yet, might try another one.
Post #537528 Fri Oct 06 2017 2:04pm
They all start SA I think, the bit you need is the two letters preceding the last Six digits i.e. AA215623 - CA759577. If you go into the on-board menu to service where you check oil level, you can also display Vin. No.
Post #537569 Fri Oct 06 2017 5:56pm
tom0311
Ah - in that case my VIN is in that range. I've forwarded the TSB to the garage as well. Thanks again Col - you are a fountain of knowledge.
Post #537571 Fri Oct 06 2017 5:58pm
No I'm just a sad sod with nothing better to do. Rolling with laughter
Post #537572 Fri Oct 06 2017 6:00pm
tom0311
Booked in for the end of the month. Had a warning that it could be super-expensive, not looking forward to the bill. Not much else I can do with it though, so I'll just look forward to having it healthy again!
Cheers for all the input.
Post #537839 Mon Oct 09 2017 11:50am
Page 3 of 4 <1234>
