Home > Detailing & Car Cleaning > Poorboys SSR1 and Blackhole
SVR575
What would you recommend David?
Ok thanks Socast. SVR 2018 in Santorini Black.
Post #536961 Mon Oct 02 2017 5:43pm
d-9
Socast wrote:
TDV8HST - That's not bad, but it's not a DA orbital, it's basically an angle grinder..
Not really. Much lower speed (and variable speed), higher torque than a grinder.
I never got on with a DA, seemed to take much longer and be harder work to get results. I use a silverline rotary polisher in conjunction with the 3m perfect-it pads and compound/polishes.
Post #536989 Mon Oct 02 2017 8:42pm
david007
United Kingdom 2011 Range Rover Sport SDV6 SE Vesuvius Orange
Ok thanks Socast.
I've got a DAS-6-PRO dual action and also the Silverline rotary and to be honest I only use the DA now, that's probably down to the fact that the paint work only needs a very minor correction now and then. I would think that any of the DA's recommended on this thread would do the job, a lot of people seem to have had good results using the Challenge DA that Argos sell.
http://www.argos.co.uk/product/4645777
Post #537007 Tue Oct 03 2017 6:48am
SVR575
Ok guys i have been looking at this below. It is a 710w machine compared to the DAS 6 which is 900w .
Das 6 costs more and has no pads , do you think this one is powerful enough and a good buy?
http://www.ebay.co.uk/itm/DUAL-ACTION-ECCE...0033.m2042 SVR 2018 in Santorini Black.
Post #537085 Tue Oct 03 2017 2:21pm
david007
Just had a quick look on detailing world and found this review
http://www.detailingworld.co.uk/forum/showthread.php?p=5120154
The only other thing you might need is a couple of different cutting compounds.
Oh by the way you might find yourself on a bit of a slippy slope now, as next after correcting your paintwork you'll need some sort of protection be it either a wax or sealant, then you'll probably need a snow foam lance, then you'll have to use the two bucket wash method to stop most of the micro scratches from happening again, then you'd probably want a detailing spray to use after a maintenance wash, etc etc.😜😀👍
Post #537142 Tue Oct 03 2017 6:49pm
SVR575
Hi David, yes i did see that. I have every thing as i usually do my cars by hand and the paint on them is superb . But some times the car picks up a light scratch even when waxing or polishing so i want to be able to remove these without popping down to my body shop. So really i don't need any thing to extreme, just back up.
Thanks for you help. Thumbs Up SVR 2018 in Santorini Black.
Post #537158 Tue Oct 03 2017 7:37pm
SVR575
Post #537159 Tue Oct 03 2017 7:37pm
Socast
So I bought one of these the other day:
https://www.amazon.co.uk/gp/product/B01IR3...&psc=1
It's an AMAZING bargain, the polisher is well made and doesn't feel cheap, it has an analogue speed controller near the power cord and while I haven't used it yet it feels to have oodles of torque. The kit comes with a decent storage/carry case for the polisher and a cart load of heads and other accessories, oh and it also comes with an extra set of brushes for the polisher!
Shipping was pretty quick too Very Happy
Post #537214 Wed Oct 04 2017 7:38am
SVR575
Socast its the same as i was looking at on eBay, yours was cheaper though. Let us know how you get on with it sure looks good though. SVR 2018 in Santorini Black.
Post #537273 Wed Oct 04 2017 2:36pm
Socast
Had a quick go with the buffer over the weekend and I'm really impressed with it. Loads of torque and plenty of speed (controllable), I did rotate the body so that the on/off switch was at the top as I found it awkward to slide/press the switch, it's a quick easy job, just 4 screws, pull the body away a little, twist and then replace the screws.
My only real gripes with it are that there is quite a lot of vibration transfered to my hands, so white knuckle is a destinct possibility if using it for long periods (I'm currently mulling over how I can soften the vibrations, pipe insulation for the handle is obvious, but the body has me stumped haha).
The other is that the half-moon handle has to be removed for the buffer to go back in it's case, it's a very minor thing really, but it's still a couple of mins faffing about taking it apart and putting the bolts and tools away safely and vice-versa.
But other than those two niggles it's a great piece of kit and a fraction of the price the named brands are charging Thumbs Up
Post #537980 Tue Oct 10 2017 1:47pm
david007
Cheers for the update, shame about the vibration, perhaps you could try something like this if you were going to use it for a long time. Not sure if they rob you of any dexterity though.
https://www.screwfix.com/p/cutter-cw700-an...0wodukYMkQ
Post #537981 Tue Oct 10 2017 1:52pm
SVR575
I have just ordered one so good to hear its not so bad.
Might get the gloves as well David. SVR 2018 in Santorini Black.
Post #538013 Tue Oct 10 2017 6:09pm
