Home > Detailing & Car Cleaning > Poorboys SSR1 and Blackhole |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1826 |
What would you recommend David?
Mon Oct 02 2017 5:43pm |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 |
I've got a DAS-6-PRO dual action and also the Silverline rotary and to be honest I only use the DA now, that's probably down to the fact that the paint work only needs a very minor correction now and then. I would think that any of the DA's recommended on this thread would do the job, a lot of people seem to have had good results using the Challenge DA that Argos sell. http://www.argos.co.uk/product/4645777 |
Tue Oct 03 2017 6:48am |
Ok guys i have been looking at this below. It is a 710w machine compared to the DAS 6 which is 900w .
Tue Oct 03 2017 2:21pm |
Just had a quick look on detailing world and found this review
Tue Oct 03 2017 6:49pm |
Hi David, yes i did see that. I have every thing as i usually do my cars by hand and the paint on them is superb . But some times the car picks up a light scratch even when waxing or polishing so i want to be able to remove these without popping down to my body shop. So really i don't need any thing to extreme, just back up.
Tue Oct 03 2017 7:37pm |
So I bought one of these the other day:
Wed Oct 04 2017 7:38am |
Socast its the same as i was looking at on eBay, yours was cheaper though. Let us know how you get on with it sure looks good though. SVR 2018 in Santorini Black. |
Wed Oct 04 2017 2:36pm |
Had a quick go with the buffer over the weekend and I'm really impressed with it. Loads of torque and plenty of speed (controllable), I did rotate the body so that the on/off switch was at the top as I found it awkward to slide/press the switch, it's a quick easy job, just 4 screws, pull the body away a little, twist and then replace the screws.
Tue Oct 10 2017 1:47pm |
Cheers for the update, shame about the vibration, perhaps you could try something like this if you were going to use it for a long time. Not sure if they rob you of any dexterity though.
Tue Oct 10 2017 1:52pm |
I have just ordered one so good to hear its not so bad.
Tue Oct 10 2017 6:09pm |
