Home > Faults & Fixes > Slight engine misfire after fuel filter change
R1CHD
United Kingdom 2005 Range Rover Sport TDV6 SE Java Black
Hi
I have a slight misfire under low revs/load after replacing my fuel filter, it runs fine at idle and seems to pull ok but I have what sounds like a slight misfire, when I replaced the filter I didn't fill it full of fuel but I did prime the system ( ignition on for 30 seconds and then off) I released the air from the fuel bleed fitting above the engine cover and it started ok and now starts fine every time, any advice would be great
Thanks
Post #536985 Mon Oct 02 2017 8:28pm
R1CHD
I put a diagnostic code reader on the car today and there’s no active fault codes, has anyone had any injector problems?
Post #537714 Sun Oct 08 2017 9:18am
geoffsnook
Get some bk44 cleaner from ebay for yours put it in it's supposed to be quite good for cleaning engine's/injector's Thumbs Up
Post #537722 Sun Oct 08 2017 10:15am
Isn't BG44K what L/R recommend for petrol engines?. Might be BG244 for diesels.
Post #537723 Sun Oct 08 2017 10:24am
geoffsnook
That it may col forgot for a second mine was petrol Rolling with laughter Embarassed
Post #537725 Sun Oct 08 2017 10:37am
raysheppard1954
hi ,i would think the problem is with the filter ,maybe there is a air leak on the fitting or pipe work,was the misfire there before you changed the filter.
Post #538045 Wed Oct 11 2017 5:31am
shakeapaw
Did you replace it with a genuine one, or a Europarts crap one? 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #538424 Mon Oct 16 2017 12:23pm
