Home > Technical > Which are the correct Apative Lights for my car?
MartinsTDV8
Scotland 2007 Range Rover Sport TDV8 HSE Buckingham Blue
I have a 2007 RRS HSE and the OSF headlamp has died. The yellow adaptive warning was flashing for a few days as well.
The part number on mine is XBC501763LZN. Obviously I dont want to pay the price for a new part, but there are lots of other 2nd hand lights for sale with slightly different codes.
Is the above code the only one to fit? Or will other fit and work just as well? Previously owned 1999 Disco 2 TD5
Disco 3 HSE TDV6 2007
Gone 2007 TDV8 RRS1 in Buckingham Blue.
How do know if the knocking at the front has been sorted?
You can hear the knocking at the rear better
Post #536699 Fri Sep 29 2017 3:28pm
GodivaNige
You need a ‘RH adaptive bi xenon with corner light incl controller’
Your part number is superseded by number LR012440
Other part numbers also superseded with the same number are XBC501762LZN, XBC501763LZN, XBC502280LZN
LR Direct have in stock Hella branded OE at £435 Much cheaper than the same product in a Land Rover box at over £1100 Shocked
https://www.lrdirect.com/LR012440-Headlamp-And-Flasher/
Post #536707 Fri Sep 29 2017 7:39pm
geoffsnook
http://www.island-4x4.co.uk/headlamp-hella...23254.html
Post #536710 Fri Sep 29 2017 7:49pm
GodivaNige
Good find geoffsnook Thumbs Up
Post #536711 Fri Sep 29 2017 7:59pm
geoffsnook
Post #536712 Fri Sep 29 2017 8:11pm
MartinsTDV8
Thanks gents, but I think I'm more confused than ever. Why are there so many different codes? And does it mean that there is a range of them that will fit and work?
Is the main dipped headlamp not replaceable itself? Question Previously owned 1999 Disco 2 TD5
Post #536717 Fri Sep 29 2017 8:49pm
GodivaNige
Can’t answer that, if I had to guess, little modifications and updates generate new part numbers for essentially the same item. I’ve noticed it happens a lot with LR. I recently replaced the radio/6CD in mine and there were numerous part numbers that were suitable.
As for dismantling the headlight and just changing the adaptive dipped beam, again, no idea but others might. Personally I’d replace the whole thing with a new one if it were mine that had failed. If buying a used one, you might be lucky but there’s always that risk of it failing within a short time, throwing money down the drain.
Post #536726 Fri Sep 29 2017 10:05pm
Eaters
There are many threads on this forum about these headlights. Brand new from LR they are around £1,000!
I don't know of anyone whose found them serviceable.
Be aware that some have replaced various bits of the headlight wiring and control systems but not fixed the problem so make sure your are as certain as you can be where the fault lies before spending money. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #536731 Fri Sep 29 2017 10:51pm
MartinsTDV8
Cheers guys, I dig a bit deeper now. Censored Previously owned 1999 Disco 2 TD5
Post #536794 Sat Sep 30 2017 7:33pm
