Home > General > Engine top end strip down |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4777 |
yeap I think the small breathers are on an 8mm bolt. |
Sun Sep 24 2017 8:56pm |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 |
Got that damn bracket off the back of the RH side eventually, what a that was, after having such an easy time initially stripping the RH side down.
Wed Sep 27 2017 2:23pm |
That was quick.
Wed Sep 27 2017 5:19pm |
Yes after doing the LH side any other job was going to be quicker.
Thu Sep 28 2017 8:31am |
I'm setting up the cam timing just now on the RH side and noticing that the inside smaller cam (can't remember if this is the inlet or exhaust cam)... should sit in place and lobes not touch any of the lifters?
Sat Sep 30 2017 9:23pm |
Don't worry. Nothing wrong.
Sat Sep 30 2017 9:46pm |
Superb!!! PHEW... was hoping you were going to say that. Thanks again Andy. RRS 2.7 HSE Stornoway Grey
Sun Oct 01 2017 9:09am |
OK, update on my saga is that timing belt is on and then hand cranked a good few times to get the tensioner pulley just right in the small window. Only thing I have noticed is that when I hand crank it round and all the marks line back up after two cycles of the crank the two cam locking pins go in no problem but the flywheel locking pin is a few millimetres out, what I mean is I just need to turn the crank (with top cam locking pins still in) round a fraction to get the flywheel locking pin in place.
Thu Oct 05 2017 8:43am |
I wouldn't worry. |
Thu Oct 05 2017 12:03pm |
Good... cheers Andy, I just like to check these things as I encounter them. RRS 2.7 HSE Stornoway Grey
Thu Oct 05 2017 1:06pm |
LG8340 Member Since: 27 Jul 2014 Location: London W4 Posts: 336 |
On and on like Atiston! RRS (MY13) Santorini Black SDV6 HSE luxuary
Thu Oct 05 2017 1:36pm |
Got it started thanks for the advice throughout Andy and the others who gave some invaluable advice. Got some tidying up to do i.e. had a couple of diesel leaks and the message on the dash is reporting about the gearbox, it has an 'F' where is usually shows the gear it is in!
Tue Oct 17 2017 8:45pm |
Wondered how u were going.
Tue Oct 17 2017 9:16pm |
The easiest way to get air out of the suspension is take it to a Range Rover specialist? RRS (MY13) Santorini Black SDV6 HSE luxuary
Tue Oct 17 2017 10:20pm |
