Home > Maintenance & Modifications > TDV6 and SDV6?!?
Sit
United Kingdom 2012 Range Rover Sport SDV6 HSE Firenze Red
TDV6 and SDV6?!?
Ok so I figured the 2009 facelift of the RRS when it became a 3.0 diesel unit meant they were all SDV6 engines, however I have been reading that the TDV6 still existed - is this right?
I seem to get the impression the TDV6 was a lower powered engine and the SDV6 was a higher powered engine but both 3.0?
So a 2009 3.0 TDV6 is very much a TDV6 and not an SDV6 - is there anyway of easily confirming this? When are belts due on this engine please and would they be the same interval whether it was TD or SD?
Si
Post #536489 Tue Sep 26 2017 7:01pm
geoffsnook
if it says 3.0 then its a sdv6 a tdv6 is the 2.7 engine i believe Thumbs Up
Post #536494 Tue Sep 26 2017 7:28pm
Tyrefitter
I'm sure they did a tdv6 3.0,,2009-2011 they had the stick shift, then when they went to the rotary knob it was the sdv6 3.0.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #536500 Tue Sep 26 2017 7:51pm
Sit
See - conflicting information already! Lol! I keep finding different answers in different places. I initially assumed all 3.0 cars were the facelifted SDV6 engines, however I then started to notice a number of 2009/2010 facelifted cars advertised as TDV6, then I read somewhere 3.0 TDV6 was 225bhp and 3.0 SDV6 was 245bhp or something similar so I am not overly sure?!?
Si
Post #536505 Tue Sep 26 2017 8:02pm
geoffsnook
I thought the tdv6 was only in 2.7 and the sdv6 was when they went to the 3.0 and yea you could still get the 2.7 in the early disco 4 but have been wrong on numerous points so stand to be corrected Rolling with laughter Thumbs Up
Post #536510 Tue Sep 26 2017 8:34pm
Smarttech
Mine is a 62 plate and if you reg check it then it comes up SDv6. I was told they changed to sdv6 when they upgraded to the 8 speed box and power is 252 bhp. 2017 SVR. SVO Scafell grey Ebony interior
2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior. Gone
Post #536529 Wed Sep 27 2017 7:06am
and just to add to the confusion, in ZA (and I presume other ROW markets), the early D4s were labelled as 3.0 TDV6, yet the engine was the 188kW 3.0, aka the SDV6.
we also had a coil-sprung D4 with a 155kW detuned 3.0 SDV6 engine, which was badged as the D4 XS TDV6
Rolling with laughter --
Post #536531 Wed Sep 27 2017 7:51am
Sit
This was confused more when a trader friend of mine advertised a 2010 3.0 and when he input the reg into his Auto Trader advertising account which pre-populates a lot of the information about the car based on reg number, it titled the car a 2010 Range Rover Sport 3.0 TDV6!
Do the engines look different or are the 'badged' TDV6 and SDV6 on any of the engine covers??
Si
Post #536532 Wed Sep 27 2017 7:59am
Sit
What sort of reg check can you do which shows that up bud?
Might run one on this particular car.
Si
Post #536533 Wed Sep 27 2017 8:03am
NeilRRS
I have a late 2010 3.0 TDV6
I believe after the 2009 facelift , they continued to be TDV6 until some time in 2011/12 when they changed to SDV6.
Identical to look at, other than the gearstick went to rotary and the badge !
Post #536534 Wed Sep 27 2017 8:22am
Tyrefitter
You can also tell by the boot,,on the tdv6 Rangerover is across the bottom but the sdv6 is just below rear window,,unless someone has changed the boot lid.
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #536535 Wed Sep 27 2017 8:31am
Smarttech
Si
i have the total car checker app on my phone. It was a free app that gives basic details and you have to pay if you want more. 2017 SVR. SVO Scafell grey Ebony interior
Post #536539 Wed Sep 27 2017 9:21am
Sit
Ok so based on all of the above I have decided the car I am looking at is a facelift car however is still using the TDV6 engine all be it in 3.0 guise - Auto Trader as if to sell it and and it returned the details and listed it as 2953cc TDV6 so that settles it I guess.
Does this engine differ much to the 2.7 (with the exception of size!) as I got the impression from reading lots of threads on here that the 2010 model was a great improvement on the original car - part of the reason my search was for facelifts car??
Si
Post #536541 Wed Sep 27 2017 9:36am
the 3L has 2 turbos instead of 1, but beware of the issue with the cranks breaking!
this can happen at any mileage and irregardless of the year model. --
Post #536543 Wed Sep 27 2017 9:46am
Sit
Naks - not heard of this issue - how common is this?? Is there any preventative maintenance that can be done to avoid it? I am planning to buy a LR warranty as it meets their criteria in terms of age/mileage and has full dealership history so hopefully that will provide some peace of mind.
Si
Post #536544 Wed Sep 27 2017 10:47am
