Home > In Car Electronics > Subwoofer rattle
NeilRRS
Subwoofer rattle
I have the HK sound system in my 2011 Sport.
The sound system is pretty good other than the ratting subwoofer.
I thought it may be a defective/ripped speaker so I took the rear trim off today, to find the speaker intact.
Without the panel on the Sub sounded ok. I tried insulating the plastic panel but every time I put it back on, the rattle returned.
It is either a badly designed sub location or I am missing something when putting the panel back on.
A
Any ideas..?
Post #536180 Fri Sep 22 2017 4:30pm
Have a vauge recollection there have been previous posts on this issue, may have even been a L/R service bulletin on it. Can't really remember fully but a search might turn something up.
Post #536210 Fri Sep 22 2017 9:19pm
NeilRRS
I have done a search but nothing useful.
Where would I find a service bulletin?
Post #536223 Sat Sep 23 2017 6:02am
As I said only had a vague recollection, so could be getting totally muddled up with something else. If there is a bulletin of any sort should be on Topix somewhere. I assume all the panel retaining clips are there none broken or missing.
Post #536226 Sat Sep 23 2017 7:18am
NeilRRS
No. All ok. Think it is a design issue. Will just turn the sub volume down !
Post #536228 Sat Sep 23 2017 7:31am
Ian.H
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
It's a crap location! Mine doesn't rattle inside, but I grew up DJing in the 90s and like to play my music pretty turned up still... but over a certain volume (not even up near the max), outside the motor, the taigate vibrates like crazy and makes it sound like a 17 year old kid in a Saxo... definitely not very thought out by LR IMO Sad
Cheers..
Ian
Post #539034 Mon Oct 23 2017 10:51pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
I had the same issue of vibration and rattle but both are relatively easy to fix and I have put a post in tips and tricks to explain.
Post #565721 Sun Sep 23 2018 8:51am
