Home > Tips & Tricks > Demisting? |
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 |
Mine has an electrically heated front screen and its an 06. Is that not standard on later ones? Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Tue Sep 19 2017 8:28pm |
It should have the heated front screen.
Tue Sep 19 2017 8:52pm |
As stated above, they are fitted with a heated front screen as standard for that trim, a switch in central console on Mk1s and facelift 2011-2013 also fitted on MK2s (current models) as well. John
Wed Sep 20 2017 12:08am |
TAR Member Since: 30 May 2017 Location: Devon Posts: 2 |
Yes I got the heated screen, but was talking about the 'blower', which directs warm air to the windscreen and side vents for the side windows. Is it possible to run this hot, without the air con on? |
Wed Sep 20 2017 8:29pm |
Yes it is, On the 2011-2013 MK1 facelift models and I presume earlier, the fan speed on the A/C & Climate switch, the outer ring turns round and adjusts the fan speed to whatever you want, (even with A/C on you can alter fan speed to), if you turn off A/C & Climate, set your temperature to Hot or 30+C or whatever, this will run hot without said systems switched on. Hope that helps. John
Wed Sep 20 2017 9:11pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8841 |
One wonders why one would not just run climate control... 2012 SDV6 - it's missing a couple of cylinders
Wed Sep 20 2017 9:21pm |
As you say, I thought similar and always found that was the quickest way if steamed up. Must have a reason why not, and using the recirculate button assists even quicker clearing using climate control. |
Wed Sep 20 2017 9:34pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
I agree. The climate control will help remove moisture from the air (hence the water you sometimes see dripping underneath the car), so surely the quickest way is to use hot, recycled, climate controlled air. Leave the air con on. Robin
Wed Sep 20 2017 10:59pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
Well you can just turn the Econ button on which turns the aircon compressor off and switch the outlets to to upper dash (defrost) turn the fan up and turn the heat up - bit like the good old days before aircon - the RRS can do it that way.
Thu Sep 21 2017 12:55am |
SVR fan Member Since: 03 Mar 2019 Location: Surrey Posts: 28 |
prog defrost, there’s a button for that? I have a 2018 SVR - not sure I have seen that? |
Thu Mar 07 2019 9:51pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
Think it was only the earlier RRS1 that had the "Econ" button.
Thu Mar 07 2019 10:24pm |
Cheers col |
Thu Mar 07 2019 11:38pm |
Prog Defrost on my 2008 RRS turns on both front and rear screen heater elements and directs the a high air flow to the front screen. All at the push of just one button. Robin
Fri Mar 08 2019 8:54am |
Lynchy Member Since: 24 Oct 2021 Location: Newcastle Posts: 80 |
Is the Air Con on constant? Just with the ECON comment there, and the fact im running 12mpg |
Thu Jan 20 2022 12:07pm |
