Home > Faults & Fixes > Another Air con question |
johnsporttdv8 Member Since: 02 Nov 2014 Location: Cambridgeshire Posts: 16 |
I really had hoped you would not have said that. very bad news guess.
Mon Sep 18 2017 10:52am |
Have a look on fleebay a lot of them ask for your ref so they can comfiem the pump will fit and then maybe take it to an indie if you don't want to fit it yourself |
Mon Sep 18 2017 11:13am |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
https://www.advancedfactors.co.uk/lr014536...3400-p.asp
Mon Sep 18 2017 11:17am |
The advanced factors price seems to be the cheapest so that is what I will have to do.
Mon Sep 18 2017 12:49pm |
The valves within a compressor break when the compressor pumps liquid refrigerant. So, the mileage of your car is irrespective to this problem.
Mon Sep 18 2017 1:01pm |
See this thread re discount http://www.rrsport.co.uk/forum/topic42096.html |
Mon Sep 18 2017 1:04pm |
If the Compressor is genuine LR and was supplied by LR, they all carry a full 2 year warranty, so reading how long you have had it, it should be covered for replacement under Warranty. The 2 year guarantee is now applicable to all LR genuine supplied parts. John
Mon Sep 18 2017 1:28pm |
GodivaNige.
Mon Sep 18 2017 5:15pm |
Forget the expansion valve, it is rare they fail in automotive systems.
Mon Sep 18 2017 5:26pm |
Thank you!
Mon Sep 18 2017 6:59pm |
GodiveNige.
Tue Sep 19 2017 4:07pm |
To verify if your compressor is faulty, take your car to a (qualified) air conditioning engineer (not someone who has had an hour training on a machine) and ask for it to be checked. Using a manifold gauge an engineer will be able to tell immediately if the compressor is faulty by viewing the suction and discharge pressures. A faulty compressor will show less of a differential between the suction pressure and discharge pressure in comparison to a healthy compressor. An engineer will know what pressures to expect from a healthy compressor for the given ambient and cabin temperatures at the time of testing.
Tue Sep 19 2017 4:32pm |
